Key Fob Accidental Alarm Activation
Pic-N-Stick
Northern Virginia, USA
Retired Firefighter
Last night at 10pm I accidentally set off the alarm via the key fob. I carry the remote in my pocket with other keys, etc. Does anybody use a protective sleeve that prevents the buttons form inadvertently being pressed? Or at least makes the buttons harder to press? Any other solution you've come up with?
embedded rock
Earth
One truck, two motorcycles
Because of all the Ranger's electrical business after just opening a door while parked in the garage, I leave my RR key in the kitchen when home.
I’ve done
it too. I have a lanyard, and I do put it in a drawer. But stuff happens
i saw there was a forscan setting where the panic alarm could be changed to two Pushes. I think that would help.
I hadn’t thought of a cover
natethegreat42
Nate
Minnesota
Ford Taurus
I have been nervous about this since I bought the truck. Then again this would be with most new vehicles just with how some of the key fobs are designed now. But I have only done this twice somehow. I typically don’t have issues with bigger pockets, but with tighter ones that is where I have accidentally set it off.
Anyone else accidentally set it off and it’s like you just forgot how to use the incredibly simple remote? 😭
Pic-N-Stick
Pic-N-Stick
Retired Firefighter
Yep! I started her up last night in the process of shutting off the alarm!
boraxman
Santa Clarita, Ca. USA
Been there, but at 3.45am...Im sure my neighbors were like WTF.
AugPal
Augie
Chicago
Retired IBEW
My wife would put the keys in her purse and set off the alarm constantly. She now hangs the keys up when she's home and in her pocket when she goes out.
Glisch
Houston, Tx
I’ve set it of 5+ times in 3 weeks of ownership
I never had an issue accidentally triggering the alarm in previous vehicles. This is my first ford purchase, so not sure if it’s always this easy or just the shape of the fob, etc
The forscan update to require 2 presses seems promising. Can I ask the dealer to make that change, or is that something I need to get a forscan tool to do?
Massman
Ed
MA
2024 Ranger Lariat
Ive done it on two occasions, both while sitting and tying my boots with the fob in my pants pocket. Now if I am going to have it in my pants pocket, I put it in this pouch I got on Amazon to block the the fob's signal. This prevents any accidentally pressed buttons from sending a signal to the truck.
Wisdompro RFID Key FOB Protector for Car Key Signal Blocking, WP4697 Faraday Bag for Anti-Hacking, Anti-Theft Pouch
porgey
George
Bloomington Il
2024 Ford Ranger XL Blue
HD truck mechanic
yep me also just get in pocket to get and it goes off...double tap be nice!!
LDHunter
Bob
NW Florida
Real Estate
When I get home I put my fob in a faraday box I got on Amazon. I find it to be way easier to use than the pouches. I just flip up the lid drop in my keys including the key fob and push the lid down. Easy peasy.
got3fords
James
Central Va.
Reviving this because I just got a new '26 RR. I must be misunderstanding the owners manual, because I tried leaving the fob in the truck and it beeped and would not lock. The owner's manual suggests you can leave it in the truck, hit the lock, and the FOB becomes inactive until get in and press Unlock.
"• The system deactivates passive keys left inside your vehicle when you lock it. You cannot switch the ignition on using a deactivated passive key. Press the unlock button on the remote control to reactivate a passive key."
So is the only way to leave a FOB inside a faraday bag/box?
Pic-N-Stick
Pic-N-Stick
Retired Firefighter
Sorry, can't help you with that. But I did get covers for my keys. They have worked perfectly! Buttons can still be pushed but I haven't inadvertently set off the alarm, locked or unlocked my truck.
Ford Ranger Key Fob Accidental Alarm Activation 1776440276455-it
Amazon.com: MAIMOCCY Key Case Fob Cover Compatible For Ford F150 F250 F350 Edge Explorer Mustang Raptor Bronco Fusion Lincoln Nautilus Accessories Key Shell Holder Case Bag Protector : Automotive
OxygenMask
Phil
Eugene, Oregon
It was my understanding that only works if you have a keypad.
So I just tested mine. Took one fob outside,
It will let me lock a fob in the truck if I lock the truck with the keypad.
If I lock and shut the door it honks and unlocks.
If I have the other fob in my pocket, it will let me lock a fob in the truck.
