Looking for ideas for securing things to bed floor
dmac72
California
Something I really miss about my Tacoma was that it came with tie down anchors on the floor of the bed (one in each corner). This was handy for holding down boxes and gear that are lower than the tie down points on the bedsides/cargo rails.
For example, tying down Maxxtrax boards or a hi-lift jack to the bed floor so they don’t go flying out when I’m wheelin. My truck is my daily driver, so I’m not looking for ways to permanently attach those items to the vehicle.
Before I drill holes and add anchor points of my own, I’m curious to know if anyone has any ideas or has utilized some other approach. Thanks in advance!
TheRealSasquatch
Bronco
I am looking into the same methods for my Truck. I am planning on taking a trip to Baja in my raptor and need a second spare to fit in the bed. I don't want to stand the spare tire up like the Racers do. I would like to keep a tonneau cover over everything.
In the F150 Raptors the chase Racks that don't break the beds are tied into the bed bolts and into the frame of the truck. Nearly nothing of real weight is attached to the the bed rails to limit strain and fatigue of the metal. I am wondering if the Ranger Raptor Beds will have the same issue. I am pretty sure the bed won't take that shaking since Ford limits 88lbs above the rails for normal use.
The Rangers bed is bolted from the underbody best I can tell . We can't attach racks the same way as the F150.
I am looking into using L-Track on the flat spot over the frame rails. This and almost every other option I come up with requires drilling the bed which I am not thrilled about. The Bolts will need some huge washers or backing plates to spread the strain and not crack the sheet metal.
Anyone else have a more creative ideal than I have come up with?
Narwhal Truck Toppers
Richie
24 Ranger Raptor, 21 X5 M50i
TheRealSasquatch
Bronco
There are no bed bolts looking from the top in the Raptor. The bed is mounted from underneath. If you look from the rear corners of the truck and look almost above the rear axle it’s possible to see the bed mounted to the frame brackets from underneath.
I am leaning towards L-Track if no other solutions on the aftermarket pop up this year. I don’t need to drill any holes immediately. I am probably going to attend the Texas Raptor Run this summer and see if what’s on other rangers.
A current example available on the aftermarket for $1700 raw and 1950 coated. Spendy!
SDHQ 24’ Ranger Raptor Chase Rack
macky
Central PA
'24 Ranger Raptor Shelter Green
BuiltRight has a nice bedside panel system for the 19-23 Rangers. They don't have them listed for 24-25s yet.
https://builtrightind.com/products/bedside-rack-molle-truck-bed-panel-system-ford-ranger
This is the route I'm planning to go. Their newsletter today says availability in Q1:
Among other things, you can anticipate a Q1 release of the following: 2nd Gen Colorado/Canyon Bedside Racks, 2024+ Ranger Bedside Racks, 2024+ Tacoma Bedside Racks and 2024+ HD GM Dash Mount
dmac72
dmac72
California
Yeah, this is probably the move—assuming the panel comes down low enough towards the tailgate side.
MoBob
Bob
Ofallon MO
2023 F150 Raptor, 2024 Ranger Raptor
I did the L track in my last Raptor. It was a little bit of a pain to install and get the holes lined up where needed. It really worked well regardless of what I was tying down. I miss it on my new trucks and will probably end up spending the time to do it again.
Cametotruth23
Minnesota
F150
I missed that about my Tacoma and ended up buying some ram promaster cargo tie down rings on ebay. I did have to cut into them a bit and they don't spin but they did fit on the bed bolts.
It works. I don't yet have a ranger so I don't know if they same setup would work or not. If the bed bolts are smaller it may be possible to get them to spin.
Bushmechanic
South East United States
I'd love to give you an idea, but I ran through the same thought process after pondering where I'd put what. I came to the conclusion that once you've had longitudinally mounted rails, you're not going to be satisfied with much else.
If I keep this Raptor for any length of time, I'll have to drill some, as well.
Ford Ranger Looking for ideas for securing things to bed floor WP_20180912_20_07_03_Pro
Ford Ranger Looking for ideas for securing things to bed floor WP_20180911_16_12_55_Pro
Ignore the spray paint. I backed over a bag of cans a while back with the bumper off. Yes, it got on the bodywork, as well. Yes, it took forever to clean off. No, I still haven't heard the end of it.
These were made and sold by Hi-Lift, including the rings. Very nice stuff that will hold a lot, but I'm not sure you can get those specifically anymore. They were super expensive, anyway. I'm sure there are other options available, if these are totally out of production.
It looks like they sell "Trail Track" now, which features the same nice rings, but with a slightly more finished look.
