Most Popular FORSCAN Changes
21VBRanger
Bo
Overland Park, KS
2024 Ranger XLT Supercrew
Travel Agent & Compliance Manager
I saw that turn signal option in there when I was doing a deep dive. Ill have to go back and figure out where it was again. For the seatbelt screen, just use the codes mentioned above. It worked.
Thanks! I will look again too.
AlpineBike
Banned
Banned
Andrew
Waitsfield, VT
I often turn the truck on (hit the button without holding down brake pedal) and switch the exhaust the Baja, then start the truck up. It’s a pain but if you want that loud start..
I didn’t know you could do that.
Will have to give it a try.
Thanks!!
bubba Dave
kansas
2024 ranger
old
I tried finding the turn signal from 3 to 5 but not able to locate it. Anyone know where it is?
Also wanting to turn off the seat belt buckled screen on the speedometer when someone buckles/unbuckles.
It in the SCCM steering column control module, I got mine changed.
Cacciola
Giacomo
Rio de Janeiro
2024 ranger raptor
Business
I started one by painfully taking screen grabs and typing them in, basically every item whether it applies to Ranger or not. I wasn't going to post this until done, but here ya go: ForScan-2024Ranger.xlsx Still very much a work in progress, and you can ignore the coloring for now. This is probably overkill....But that's how I roll.
It'll be a few weeks before I do the rest as I'm going on vacation.... Then at some point we can collaborate as to the code values and what actually works.
Awesome work! Keep us posted on updates.
If you need help, we can make it collaborative, just instruct me what to do.
miniR
NC/AZ
I have nothing in the ”lighting” tab to turn on or off Welcome Lighting, I like this option on my F-150 Raptor, but it isn’t present on my RR. Owners manual mentions it.
And there is no “Windows” tab at all, I’d like to have the Global windows option.
Will I have to use Forscan to turn these features on?
craigc
Craig
Allen, TX
Where is the Bambi mode located? I didn't see it clearly defined in the spreadsheet.
Working on a refined version of the spreadsheet for better public consumption, but not quite there yet.
Have not tested on ranger yet, but this is from F150:
LightsFogs on when high beams are on (aka Bambi Mode)BCM726-39-02xxx0xxxxxx--Default is 1, which turns off fog if high beams come on. setting to 0 allows turning on the fog lights even if high beams are on
I believe this also can be changed in the NON-ASBUILT BdyCM Menu:
Using Front Fog With High Beam (default is inhibited)
It worked with just the non-asbuilt change!
Try this?
Ford Ranger Most Popular FORSCAN Changes 1725912984431-4
PatrickKnight
Patrick
Indy
Service Advisor
So this truck has an option in the settings under vehicle for “quiet start”.
Am I the only one that would like an option for a loud start?
Would be cool to be able to cold start the truck with the exhaust in “Baja”.
Maybe this is something that could be figured out in Forscan?
You literally read my mind. Has this been figured out?
