Need Help with Keyless entry pad
Highspeedplay
My Raptor was ordered with dealer install Keyless entry, It was not available when I picked up the truck and now I need to know is this colored coded to the truck or is it flat black. Some pics show it both ways.
I dont mind waiting for the colored matched . But if its going to be black I will make them get it from another dealership. I know this can be added later as an accessory . thanks
midnight270
NNJ
2025 Ranger Raptor CGM
I have a 2025 and my keypad was black. I haven't seen a color match one.
fordtrks4ever
Perkiomenville, Pa
2024 it was color matched
2025 black only (mine came with one)
I moved it to inside of gas door
johnalan
Yakima, WA
2024 Ford Ranger XLT
Public Safety Consulting
I moved mine into the inside gas door like fordtrks3ever did... I may have got the idea from him.
midnight270
NNJ
Mine is in the fuel door too 😂
Highspeedplay
Highspeedplay
Thanks
Mikein the burg
Williamsburg, VA
2025 Ranger Raptor, 2019 Mercedes E400, 2005 BMW C330i, 88 Jeep Comanche
Real Estate
MIne is on the door. Is it hard to remove? I like the fuel door option.
fordtrks4ever
Perkiomenville, Pa
I used a thin nylon string to remove
some use dental floss.
Hardest part was removing the remaining tape from drivers door
I used 3m tape to reattach to fuel door
Ag3ntC00p3r
Product Manager
It is removable. It is just a 3M type tape.
My dealership accidentally installed mine on the door when I wanted it in the fuel door. They were able to remove it and put on new tape to stick it to the fuel door.
Mikein the burg
Williamsburg, VA
Real Estate
Also, dealer told me the Dealer Installled unit cannot be programed through the control screen and I am stuck with the current code.
fordtrks4ever
Perkiomenville, Pa
To reprogram a Ford Ranger door keypad, first enter the five-digit factory-set code, then press the "1•2" button within five seconds. Next, enter your new five-digit personal code, press "1•2" again to save it, and the doors will lock and unlock to confirm. You can find the factory code on the owner's wallet card. The factory code will also still work.
This how I put my personal code in
Must be done using the keypad
midnight270
NNJ
This how I put my personal code in.
This is the way. I could not set my own code from the control screen in the truck. You need to do it with the keypad.
Highspeedplay
Highspeedplay
Any pics on the fuel door to what this looks like. I am used to the up and down style on the door pillar.
