New fun problem! Automatically switching drive modes
Phlfwd22
Matthew
Tampa
Firefighter
Anyone else’s do this yet? Was driving normal when the truck decided it wanted to start cycling between drive modes / 2-4 wheel drives.
wlarsen76
Wells
Yes! Mine has done it twice since May. I can't duplicate it, so I never brought it in, but it has done it. It wanted to switch to Rock Crawl while I was driving 75 mph.
An error just came on the screen and told me to come to a stop first.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
Hello, I would like to see if I can assist you with your drive mode concerns. Could you please send us a message with your VIN and mileage?
Flashe30
Belgium
'23 Ranger Raptor, BMW e61 M5, BMW e34 M5 3.6, ...
Knob is sticking or acting up
UpInTheAir
NA
Patience
Yep, mine started cycling between normal, sport, haul, baja, etc. once while I was driving a couple of weeks ago. I hadn't touched the knob/dial for at least a couple of weeks prior to that so it definitely wasn't stuck. It is the only time it has happened (so far), and I am hoping it remains the only time I experience it.
Riccardo
Riccardo
Italy
Ford Ranger Raptor T9 2.0 diesel
It happened to me twice as well (I now have 24,000 km) and I have the diesel version for Europe, of course. Both times it happened (fortunately) when I was stopped, and it also automatically engaged the rear differential (the diesel version doesn’t have a front differential). A very bad situation!!!
T-Rev
There was another thread on here mentioning the same behavior. I've also experienced it a couple times when nothing has been near the dial nor was it used recently. On the other hand, I also know I've bumped it a few times when putting my drink back in the cup holder.
SyphioD
Central Coast, CA
Just adding to this since I missed this thread and started my own about it - I've had this happen twice now while driving, both times the truck changes into sand mode from my standard sport/2h daily driving mode which engages the change to 4h.
I know for a fact nothing was touching the dial at the time this happened. I believe there may be some kind of interference to the dial when this happens as my charging cables and phone are typically near it.
Another interesting thing happening when this occurs is even if you stop and switch out of this mode, restarting the truck prompts you to re-enter sand mode.
Personally I think an update to the system should prompt a dialogue box and require an "OK" selection before moving into a mode while driving. It's alarming when this happens and not intended.
The old dude
2023 Bronco Wildtrack 2024 Ranger RAptor
Mine has done it a couple of times as well. Pretty sure it aint supposed to go into rock crawl at 60+ MPH !
CAFarmer12
Ken
Elk Grove California
2019 F250
Farmer
I have experienced the same problem. I even put tape on the switch and it still changed drive modes.
CAFarmer12
Ken
2019 F250
Farmer
I have found that by pushing the outside ring on the mode switch down, it sometime shifts all the wat to sand and rut. It does happen everytime. Only when it wants, It goes through all of the modes when it does happen.
Bushmechanic
South East United States
This has now happened to me twice. The vehicle had less than 500 miles on it. Now it's around 550.
Once, at around 50mph, it began rapidly cycling through drive modes before landing on Baja. It then attempted to shift into 4WD low range. Eventually, the "preconditions not met" notification popped up, given I wasn't stopped, and I was able to continue my drive unimpeded.
The next time I was parked and idling, and it managed to switch itself to rock crawl mode.
Zero driver input in regard to mode selection was involved, and I was nowhere near that knob. The road was smooth and level, it was a nice 70 degree evening, and all was right in the world until that happened.
I took it to the dealership, which was, of course, unable to replicate the issue. I stuck with it nevertheless, and eventually spoke with the service manager, who gave me a (surprisingly simplistic) form to fill out, and some manner of customer service number which I haven't called yet, as I only got it yesterday.
I'm still in the early stages, but I will say this is a fault that ought to deadline the vehicle. One really shouldn't be driving a vehicle who's suspension can be altered suddenly and without notice; and may the powers forbid any day that "you must be stopped" failsafe fails to function.
Ford has a firecracker in their hand, with this one. It's only a matter of time before it startles someone into a collision, or adjusts the suspension in a turn during a rainstorm on a rough road.
Sako887
Sarkis
Los Angeles
2019 Ford Ranger
Had this happen to me yesterday. 10k miles on the RR and it’s the first time it’s happened. Switched all the way to Baja mode while going 70+ on the highway. Anyone have any updates on the issue and/or resolution?
Bushmechanic
Mine did it again two days ago. It went all the way to Baja and locked me into 4WD high.
This is unacceptable. It's a SEVERE safety risk. I'll be haranguing Ford, and may eventually push for a buyback, to move on to something reliable.
If this happened even once on a military vehicle, it would be a guaranteed DEADLINE FAULT.
Stop putting up with this stuff.
