Off road air down the tires questions
Mystic
Rusty
SoCal
'24 RR, '25 Explorer ST
Estimator
Peter949
Peter
Irvine, CA
For normal slow speed forest trail stuff on regular rims: outside of the rare freak thing happening (the guy above sliding 20 feet) there is no real risk of debeading until you get to ~12-14psi.
You can also run into issues doing high speed / fast launch stuff at super low pressures.
Recommend beadgrip tires and you basically don't have to worry any of this stuff until you get down to ~8psi.
I personally run Method 703 beadgrips and tires at ~14psi for just about everything. There was one time I set my tires to 8psi for the Gold Mountain trail, and it turned out fine..
Were you able to climb the last obstacle up Gold Mountain? I think I wasn't low enough psi or my Toyos stunk.
Mystic
Rusty
SoCal
Estimator
I took the easy line on the ledges...I still don't have skid plates, and I've already tore up one of the underbody struts, my cat, and my trailer connector (lol)
I think my wife has video of it on the gatekeeper pile though...annihilated it in like 45 seconds flat unscathed after waiting 5 minutes for the Jeep on 38s to pick his way thru.
Peter949
Peter
Irvine, CA
Funny thing is I just noticed my trail connector was crooked this morning. My truck took a beating.
Mystic
Rusty
SoCal
Estimator
I just took these ahahahahahaha I feel your pain
Edit: I need to just bite the bullet and do the relocate
Ford Ranger Off road air down the tires questions 20261113_160631
Ford Ranger Off road air down the tires questions 20261113_160635
NM Mike
New Mexico
FWIW, I used to run 8-12 psi on a dirt track stock car. Bead locks were not allowed in my class, but could run non bead locks racing wheels which have a wider seal area before the bead on the inside. Never had a bead failure, but did blow out a few tires from heat when the track dried out on the main event.
I know this doesn’t equate to running in the sand or over rocky terrain necessarily, but running under 20 psi is doable with factory beads and tires in a lot of situations. You do need to be mindful of tire sidewall temps. A IR temp gun is pretty inexpensive and doesn’t take up much room in the glovebox/center console.
ALlex858
Alex
Arizona
2025 Ford Ranger Raptor
I’ll check my notes when I get home but I think they run 32/28 front/rear at Raptor school, fwiw.
At Raptor school, the trucks were not "aired down, they just set it at that pressure to keep the course moving due to the varied driving we all did.
