Off road air down the tires questions
Dadzmad
Basil
SoCal
2024 Ranger XT
Civil Engineer
I am going to do some back road driving in the Mohave this winter near dunes northeast of Joshua Tree and have heard that airing down the tires is recommended in those areas. I have a Ranger STX 4x4 and a 12v inflator and a deflator set that I got for this. What target pressure would be recommended for a general sort of rocky roads with some larger sandy patches. I'm thinking between 20 and 25 psi or should I go lower - new to this so any tips would be appreciated.
pablo94sc
Focus
Depends on your tires, but below 28psi you risk popping the bead without beadlock or knurled bean grip wheels. I ran the ko3s at 34psi cold on most things in Moab, but in your situation, depending on tires, 30psi should be fine for anything other than deep sand if you carry momentum through it.
srv256ss
2025 Ford Ranger Raptor
I’ll check my notes when I get home but I think they run 32/28 front/rear at Raptor school, fwiw.
surfstar
CA
2025 Lariat 2.3 FX4
My door placard calls for 30 psi. FX4 255/65r18.
I'd air down to 25 and not worry about beads, or just leave it alone and only air down after getting stuck ;) Sometimes that's the recommended way of utilizing locker(s) also.
OxygenMask
Phil
Eugene, Oregon
2025 Ranger Raptor, 2012 F350
You guys are way conservative.
In a 4runner on 33s my street pressure was 35.
During hunting season or trail days we all ran 20 to 25.
On the dunes I ran 15 but most of the guys ran 10!
Decades and thousands of trail miles not one of us ever popped a bead.
But then we weren't running baja with our hair on fire....
YMMV
EFNFAST
New Hampshire
1990 ZR-1 Corvette, 2019 Ranger
YMMV
I agree, at 25 psi, you won't notice any difference. Even at 20 psi, your footprint won't be much bigger.
hjmpanzr
2025 RR; 2010 F-150 Raptor
I broke the bead on my Gen 2 f150 raptor at 36lbs while off roading. I was close to home and didn’t plan on spending much time so didn’t air down. Slid sideways for about 20 ft and popped the bead. So all sorts of things can happened.
That said, I usually air down and stay about 20-25 lbs when off roading at high speeds (50-100mph). Don’t really have reason to go below that. I don’t rock crawl and don’t get to the dunes often.
Mystic
Rusty
SoCal
'24 RR, '25 Explorer ST
Estimator
For normal slow speed forest trail stuff on regular rims: outside of the rare freak thing happening (the guy above sliding 20 feet) there is no real risk of debeading until you get to ~12-14psi.
You can also run into issues doing high speed / fast launch stuff at super low pressures.
Recommend beadgrip tires and you basically don't have to worry any of this stuff until you get down to ~8psi.
I personally run Method 703 beadgrips and tires at ~14psi for just about everything. There was one time I set my tires to 8psi for the Gold Mountain trail, and it turned out fine..
cb4017
Cliff
Northern NV
2026 XLT 2.7L FX4
I haven't needed to air down my Ranger yet, but on my 23 Colorado ZR2 and my Gladiator Mojave I aired down to 20 psi. I plan on the same with my Ranger.
Better traction and ride quality. I believe also easier on the tires. When I kill a tire on a rock it's always been when I didn't bother to air down.
Carova Raptor
NC
I live on the Outer Banks in the 4x4 area and run the tires on my Raptor at 17-20 psi year round, never had an issue, plus keeps from getting stuck in soft sand and doesn't ruin the beach or sand roads behind the dunes nearly as much as running over inflated!
