Pro Cal tune
Nikki_krause
Nikki
Hey Guys,
Just installed my pro cal tune on my 2024 Ranger raptor and I saw some people said that a good way to identify if it’s on is that the boost should reach around 24 psi however I’m only getting up to 19. Keep in mind. I installed it about an hour ago. Did you guys who noticed 25 psi see that immediately or took some time. I also noticed that on the tuner itself under module info the number the SW number after the tune was slightly different than before so I feel like that’s a good sign and I was curious if anyone else noticed that Or if everyone should have the same number after the tuner. I’m running a mix of 94 and 89 and once that’s empty I’ll go full 93. The car feels snappy for sure and shifts feel great but I’m not seeing that boost. I think it’s worth mentioning aswell that I had the dealer install it yet they did not tell me about running 91 so I returned it to stock hoping to avoid any knocking and then once I got half 94 in now put it back on.
Please let me know what you guys think or if you think the boost is normal or something’s off
Thank you,
Nikki
wolf32v
Kenneth
Arkansas
Sheltor Green Ranger Raptor.
Railroader
Yes I did see the 25psi but it depends on what sea level, temp, humidity and DA your at as to how much boost you will see. Cold denser air you will see less boost. Stock boost max was 15 so your tune is installed. Mine went from seeing 25 to max 26 psi in the fall to now in the winter 22 max and I'am in Arkansas which is at sea level.
SubaruRaptor
Jory
North
Hey Guys,
Thank you,
Nikki
As mentioned, looking at the boost isnt the way to see if its installed. Also your mixed gas is gonna cause it to behave abnormal since mixing 84 and 89 will give you a weird octane rating. Run the gas out, give it some time to learn in. If the module indicated the SW number changed your good to go. This tune is pretty small from an actual increase so its not something you are gonna be floored with on the butt dino.
Nikki_krause
Nikki
I’m in Connecticut I thought stock boost was 18 psi?
Ok I will do that and see if anything changes. Thank you
AMGRAPTOR
FL
2024 Raptor Ranger
I was at 17~18 psi before FP tune. After I always see 23-25 psi full throttle. @SubaruRaptor is right about the gas and the tune having to learn so give it some time and it will get more powerful over the next few hundred miles.
wolf32v
Kenneth
Arkansas
Railroader
Boost is based on your humidity, density of air and sea level. I was told this by Ford performance as my boost went from a high of 26 to 22 as it got colder and more humid. My max boost before the tune was 15 to 16 in my Raptor Ranger and a friends Bronco Raptor on the same day did a max of 16. After the tune it went to 26 psi max but usaully hit 25 most of the the time. When the weather changed and it got colder it was around 22. I called the tech line at Ford performance and they told me the boost presure will change based on humidity, density of air and sea level. Stock Max boost is set at 16 psi at sea level according to Ford on the stock tune. I have always ran 93 in my truck even before the tune so gas never had an effect on my boost. TFL showed before and after tune boost levels they were at 12 psi stock and after tune it was 17 psi they are a mile above sea level.
AlpineBike
Banned
Banned
Andrew
Waitsfield, VT
These cars do not use a boost target.
They use a torque target and will vary boost, timing, and a bunch of other factors to achieve a specific torque target.
T-Rev
I suspect it is your gas. I've seen similar behavior mentioned.
Another way you can check for the tune is to brake boost while stopped. Stock it won't reach near full boost, but the tune does.
chrisriner
Holly Springs, GA
Mobile App Developer
I spoke with Ford Performance and they said by looking at software version on pro call if the sw version has FP in it then it is the tuned software installed so you can confirm with that. Here is picture.
Ford Ranger Pro Cal tune IMG_0312
BradleyC
Bradley
North Mississippi
26 Ranger Raptor
Investigator
Anyone have a good sale on it right now? I should have ordered one when Ford had 25percent off. Im hoping they will have a sale for/near Christmas
NOT_RAPTOR
Cleveland
https://www.tirerack.com/engine_tun...MIgair7tHulgMV-IDCCB1GSCrqEAQYAiABEgITe_D_BwE
TireRack, but it's on back order and they keep pushing my shipping date back. Expected to ship early November.
I originally ordered from Ford and they also delayed for a week with no update before they let me cancel my order with no explanation of why they hadn't shipped it. Ordered from Tire Rack and was immediately told it was on backorder.
I'm fine with waiting to save $250.
Google and check some tuners. I forget where I got mine but it was 200 less than Ford online and that online dealer that usually has great prices
I've hit up to 27 PSI on a few rare occasions at lower RPM range (right around peak torque), also boost will taper off at higher RPM's (I typically see 19 - 21 psi at higher RPM's) and as others have said, there is not a "boost target", rather there is a torque target and ECU varies throttle, fueling and boost to achieve those targets or get as close as it can safely under the given conditions and fuel grades.
This is why intercoolers, IF PROPERLY sized and designed, can help extend turbo lifespan, especially with tuned engines, since the torque targets can be hit with less boost due to higher air density post IC (better cooling, so the turbo needs to generate less boost to hit that = less back pressure on exhaust side), however the biggest benefit isn't so much the air density, there's really not that much density change from temp as people suppose.
It's more the knock sensitivity to temperature than the air density. I ran the calculations and there's only a few percent difference in air density from say 130F to 150~170F, but the knock sensitivity is significantly higher, so the ECU pulls a lot more timing with the higher charge temps.
Ecboost love cool charge air and high fuel octane. Those two have the biggest impact on knock sensitivity. Also oil vaporization will dilute fuel octane, so good synthetic oils with low NOACK limit vaporization that gets pulled into you intake. Engines that burn oil have high knock inherently, maybe not a huge deal for NA engines, but turbo engines? Yah, they pull timing considerably when they burn oil.
Ecoboost respond very well to IC upgrades, even on stock calibrations, especially in hotter weather in the 80F+ range. It's also why in cooler weather, the stock IC's do pretty good and there's not much benefit, it's really hot weather and multi-pull runs that it makes the difference (i.e., on a summer quarter mile pass, you might be several tenths faster with an IC upgrade than without even on a stock cal due to heat related knock sensitivity, but in cooler weather you would see zero difference).
