"R" botton dead
yelnoc2
Richard
Geneseo, IL
I can change all the settings that are in the Raptor Status screen, but I can no longer save my settings or recall my previous settings with the double click of the button. While I have had frequent instances when at start up my settings screen was gone and replaced with one of the others while is was a pain I could always go back to My View, select it and scroll down a couple screens to Raptor Settings screen. Been a couple days and hasn't fixed itself, checking here before I taket to dealer which is not a real issue as ready for oil change and some recall fixes. Anyone else have this situation?
Ag3ntC00p3r
Wisconsin
Product Manager
Many have had intermittent issues with the R button. I've been lucky and only had it happen once and a shut down and restart worked for me. The standard fix is to disconnect the battery for a few minutes and functionality should be returned. If you have to do it often, then I would take it in.
GARaptor
Michael
Georgia
As previously suggested by someone else on this forum that worked for me. My R button stopped working as well. It was suggested to lock and unlock the vehicle several times with the key fob. Once I did that, all returned to normal.
ATG42
Los Angeles
24' Ranger Raptor
My R button stopped working as well. I tried turning it off and on, did not work at first. Two days later it came back on its own.
I called my local Ford dealer, they said it would take 4 days to fix this problem, I laughed at them when they couldn't tell me any more info on why it would take that long. Thankfully it just had a hiccup for 2 days and it's been working well since, fixed itself.
boraxman
Santa Clarita, Ca. USA
Mine was dead on delivery...Took negative cable off battery for a while, hooked it back up and no issues so far at 2800 miles/
Hoss
Dale
Gainesville, Georgia
Wizard
They probably had a good laugh when they hung up. Figured no one is going to wait 4 days.
jrRaptor
Maize, KS
I really think Ford should supply you with a 10mm ratcheting wrench to keep in the glovebox.
HyperM3
Alex
Lawrenceville, NJ
Welp, my R button died yesterday. I really thought it was fixed in the last software update as I hadnt had any issues for many months. Oh well. Guess Ill install the new hood struts when Im resetting the battery.
HyperM3
Alex
Lawrenceville, NJ
And just like that, it started working again yesterday. Gotta love technology.
Bt_okst
BT
Ok/Colo
Very typical on these. Happens a couple times a month to me. But it always starts working again after a few starts and stops. Obvious glitch in the electronics, but not worth losing truck for many days for a dealership to try to figure it out. Living with it for now, especially since it self corrects itself.
