YukonRanger
Yukon
Ford Ranger Wheel Calculator v1.5
  1. If there are certain tires you would like me to add, reply with your request.
  2. If you an error, or know real word specs differ from listed specs send a DM
  3. Some tires listed have been announced, but not yet released.
INSTRUCTIONS:
  1. Click on the link below to open google sheets
  2. Go to FIle > Make a copy. Now you can edit and sort.
  3. Modify red cells to calculate combined weights or custom tire dimensions
  4. Filter & sort tires by clicking on the header arrows in row 10
Ford Ranger Ranger 6G Wheel Calculator 1764324006667-e7
Ford Ranger Ranger 6G Wheel Calculator 1764324081200-rq
SOME COLUMNS ARE COLOR CODED BASED ON WEIGHT
"Greener"
means a lighter setup
"Redder" means a heavier setup
Ford Ranger Ranger 6G Wheel Calculator 1764324844422-bm
Ford Ranger Ranger 6G Wheel Calculator 1764324726030-pg
v1.3 CALCULATOR ADDITIONS
  • Rotational Mass
  • HP Loss\Gain
  • Wheel package weight
Users can now calculate the best combined wheel package weight for rims 15"-26" with all matching tires.
Ford Ranger Ranger 6G Wheel Calculator 1764818966042-ut
Lighter tires = better mileage & performance, but you should also consider:
  • Durability
  • On\Off road traction
  • Snow\Ice\Wet grip (tread + compound + siping)
  • Width & Clearance
  • Ride & Noise quality
  • Rim Compatibility
  • Load\Speed rating
  • Looks
  • Price
v1.4 RIM SELECTOR ADDITIONS
You can now choose rims from a drop down for various sizes and the sheet will auto magically calculate the wheel package weight for any tire that will fit on the rim!!! If you want to use a custom weight, simply change the custom weight field in the Rim Calc
Need help with Rim Sizes and Weights !!!!
Reply with your favourite rim in the following format:
(Brand) (model) (Diameter)x(Width) (offset) (Weight)
For Example:
Enkei RPT1 17x9 +024
Ford OEM Ranger Lariat 17x8 +5532
Ford OEM Ranger Raptor 17x8.5 +5528.3
Ford OEM Ranger Raptor BL 17x8.5 +5536.4
Ford OEM Ranger XL 17x7.5 +5525
Ford OEM Ranger XLT 17x7.5 +5531
RTR EVO 6 17x9 +024.4
RTR EVO 6 17x9 +3022.6
Vision Warrior 17x8.5 +2522.35
Vossen HF6-4 17x8.5 +3526
Vossen HFX-1 17x8.5 +3526
LATEST LINK v1.5
COMPANION TOOL TO CHECK OFFSET & POKE
WHEEL SIZE VS WEIGHT PERFORMANCE TESTING
ENJOY!
YukonRanger
YukonRanger
Yukon
Tire Code Cheat Sheet
When tire shopping these codes help you figure out what the hell you are buying
Ford Ranger Ranger 6G Wheel Calculator Tire-code-1024x576
Here's the coding breakdown for a suitable 6G Ranger 35 inch tire:
P 315/70R17 128/125S F RWL
P - Tire Class
  • P: Passenger Car
  • LT: Light Truck
  • C: Commercial trucks
  • ST: Special Trailer
  • M/C: Motorcycle
  • T: Temporary (spare tire)
  • XL, HL, or Reinforced: Tires with a higher load capacity than normal for their dimensions
  • KO: 'Key Benefit: On and Off-road' - Versatility in both on-road and off-road conditions
  • KM: 'Key Benefit: Mud' - Enhanced traction and durability in muddy environments
  • KX: ‘Key Benefit: Extreme' - Enhanced performance in extreme wet and dry conditions
  • KT: ‘Key Benefit Toughness’ - Enhanced traction and durability
315 - Section Width (tread width)
  • Nominal width of tire in MM
70 - Aspect Ratio
  • Ratio of the sidewall height as a percentage of the section width of the tire.
  • To calculate Total Tire diameter:
    • calculate twice the sidewall height (2 * width * aspect ratio)
    • convert to inches, then add rim diameter
    • In our example: (2 * 315 * 0.7 * 0.0393701) + 17 = 34.36 inches
R - Construction
  • R - Radial
  • B - Bias Belt
  • D - Diagonal
  • Omitted - cross ply tire
17 - Rim Diameter
  • Rim size the tire was designed for (inches)
128/125 - Load Index and Range
  • 128/125 = 3968/3638 lbs
  • The 2nd lesser number is the load rating for a dually configuration (in case of a blowout)
  • Load index rating can be looked up at tirepressure.org
S - Maximum safe tire speed
L75 mph120 km/hOff-Road & Light Truck Tires
M81 mph130 km/hTemporary Spare Tires
N87 mph140km/h
P93 mph150 km/h
Q99 mph160 km/hStudless & Studdable Winter Tires
R106 mph170 km/hH.D. Light Truck Tires
S112 mph180 km/hFamily Sedans & Vans Tires
T118 mph190 km/hFamily Sedans & Vans Tires
U124 mph200 km/h
H130 mph210 km/hSport Sedans & Coupes Tires
V149 mph240 km/hSport Sedans, Coupes & Sports Cars Tires
W169 mph270 km/hExotic Sports Cars
Y186 mph300 km/hExotic Sports Cars, Track & Competition
(Y)186+ mph300+ km/h
F - Load Range and tire ply rating
  • A - 2 ply
  • B - 4 ply
  • C - 8 ply
  • D - 10 ply
  • E - 12 ply
  • F - 12 ply
  • G - 14 ply
  • H - 16 ply
  • J - 18 ply
  • L - 20 ply
  • M - 22 ply
  • N - 24 ply
RWL - Lettering Designation
BSW\WSW\OWL\ORWL\RWL\RBL\BSL\VSB
Ford Ranger Ranger 6G Wheel Calculator 960px-Examples_of_different_tire_sidewall_markings
Some mfg may also have special color codes. For example RRL (raised red lettering)
Ford Ranger Ranger 6G Wheel Calculator 1761949621014-2z
TIRE PERFORMANCE DESIGNATION
  • A/T, AT
    • All Terrain
    • Tires designed for both on and off road
    • Decent performance in many conditions, but master of none
  • R/T, RT
    • Rugged Terrain
    • Tires are a hybrid between All Terrain and Mud Terrain
    • more aggressive off-road capability than A/T tires
  • M/T, MT, M+T, M&T
    • Mud Terrain
    • Tires designed for deep mud, rock crawl, deeper snow, & loose gravel
    • More aggressive off-road profile and performance than R/T
  • M/S, MS, M+S
    • Mud and Snow
    • Meets USTMA and RAC extra Mud & Snow traction requirements
    • self-cleaning tread, average traction in muddy, snowy and low temp conditions
    • Studded tires have an additional letter, "E" (M+SE).
  • 3PMSF
    • Three-Peak Mountain Snowflake
    • Ford Ranger Ranger 6G Wheel Calculator 1761942465613-kz
    • USTMA and RAC certified to meet severe snow service requirements
    • Able to exceed snow traction beyond a M+S branded tire
    • Unable to match traction and ice performance of dedicated snow / winter tires
    • Certification on medium-packed snow only. Braking, turning & ice traction not tested
  • T/A, TA
ericsmr
FordGuy
West Coast
2025 Ford Ranger XLT FX4
Do you know what light size KO3s are coming out? I was about to pull trigger on C 265/70/17
YukonRanger
YukonRanger
Yukon
According to BFG's Site
Available sizes coming in 2026
MSPNTire Size
0578830x9.50R15/C 104R
4953431x10.50R15/C 109R
0918432x11.50R15/C 113R
7318433x10.50R15/C 114R
8862733x12.50R15/C 108R
0643433x12.50R17/E 120S
8283735x11.50R17/C 118R
0334735x12.50R17/D 119R
4172537x12.50R17/C 116R
45926LT235/65R17/D 109/105S
9741033x12.50R18/E 118S
6519435x12.50R18/D 118R
03220LT235/60R18/D 108/104S
72636LT265/70R18/D 119/116S
8532833x12.50R20/E 114S
1118133x12.50R22/E 109S
0913735x12.50R22/E 117R
08937LT295/50R22/D 118/115S
252637.50R16/E 116/112R
14114LT245/65R17/D 111/108S
20879LT255/65R19/D 116/113S
17659LT265/70R17/D 118/115S (121R)
48025LT275/65R18/D 119/116S
16353LT275/70R17/D 120/117S
44053LT285/65R18/D 121/118S
92786LT295/60R20/E 126/123S
Hande
Hannu
Estonia
Business Owner
Great list! Thank you for making it! Looks like Territory MT 315/70-17 is the choice for me, being closer to M/T tire than KO2 or KO3 but still lightweight.
YukonRanger
YukonRanger
Yukon
49?! Amazing. Where did you learn this rumour?
I stumbled across it while I was getting info from the database, I noticed that the site had a bunch of tires listed without actual links to buy them, or bring up detailed info. Several of them were for tires that are coming out next year.
So I assumed the C class KO3 315\70R17 page could have been one of those tires and it was listed at 49 pounds, which is absurdly light for a tire that size.
My guess is it will be around 55, but we’ll see.
BigMeatsBronco
Allan
Oregon
self
Nice work, can you add a column on spreadsheet to search for " rim diameter " ...? thanks
