When the shutters are open with heavy throttle temps are a good 25-30F cooler than the stock IC. 0-60 pull its within maybe 10F of ambient. So far pretty significant improvement.
Now I haven't data logged anything, but did a few more pulls this morning (only at 100 miles since Adaptive KAM reset so it's not running the most aggressive timing yet as a drive cycle takes between 200 to 300 miles), ambient was 44F and with sustained heavy throttle going uphill in taller gears I would normally see 135F to 150F or more by the end of this run (right hand turn onto an uphill straight away and floor it, about a 10 degree uphill grade). So, your basically launching from a dig going uphill on a long straightaway but this time I only hit 102F charge temps, and I pushed it a bit longer than usual up that hill. In cooler weather I'd normally hit around 130~135F charge temps, in hot weather I'd easily hit 140F~150F charge temps on the stockcooler with the Pro Cal being the ONLY power adder. That is a pretty substantial change and indicates to me that the heat rejection of the CP-E is very good, especially considering its size.
It also seems like my oil temps are staying a bit cooler. Normally under such conditions I recall seeing it go from 210F up to 220F pretty quickly and oil temps only went from 208F to 212F this time, and I did quite a few pulls when terrain permitted, never got the oil temp to go up past ~212F. Now it is cooler out than summer obviously, so that could play some role but I dont find that likely to be the dominating factor in this case since ambient is only going to affect heat exchangers upper limit of cooling, not the thermal lag from mass and heat rise rates.
Things tend to heat up at about the same speed regardless of outside temps, as ambient affects the max temp they hit vs. how rapidly temps rise. Sure, if you starting at a lower temp, there's a larger delta, but the engine was already fully warmed up with 20+ miles of driving, so the Oil temp delta is lower under the same starting point with the CP-E.
So, to me that suggests between the considerably lower charge temps and the lower oils temps observed off the cuff that the turbos are seeing less heat since less boost in needed to hit the targeted air flow (colder air has higher density). Hot air has less density, so you need more boost to hit the target air flow which factors in density in the ECU strategy, which means the turbos are running further outside of their efficiency island when the charge temps are higher with the stock cooler. If the cooling system is more efficient, the ECU will need less overall boost under the same conditions to achieve the targeted air flow to meet the torque targets. And it's not going to just arbitrarily increase boost because can safely do so, there's two upper limits: 1. Torque target and 2. Turbocharger performance limit.
If you hit #1 in the ECU strategy, even if there's more capacity in #2, the ECU isn't going to demand higher boost, so the turbo isn't running maxed out = good for longevity and heat. If the ECU hasn't met the #1 and #2 is maxed out, then the ECU is not going to command more boost and it adjusts fueling and timing to match the achievable air density, you make less power but don't burn up your turbo. A better IC should theoretically make #1 far more common under heavy sustained throttle application, meaning the turbos are going to run more efficiently. I saw similar benefits with a 2.3L Ecoboost Mustang I started out with in 2015 as my first real performance vehicle (don't laugh, I later upgraded to a 2016 GT PP with 5.0L, Stage 2 Power Pack, 3.73 Torsen rear end for track days). But that Ecoboost 2.3L with a Power Pack + Intercooler (no other power adders) made considerably more RWHP than other 2.3L's even with the same the cal. and you could keep hammering it and it would maintain optimal performance.
This is good for turbo durability. The stockcooler is optimized for max throttle response and short durations of high boost, it's not by any means a piece of "garbage", but we are all more interested in the more performance-oriented use cases where the stockcooler is being pushed outside of its optimal region of efficiency. Obviously, we are all willing to pay 4x more for an aftermarket part than what an OE pays to have the factory part made and still meet their cost / durability / performance and emissions targets, for the sake of performance and reliability.
2022-2025 Ford Motorcraft™ Inter-Cooler INTCO-2 | Parts Apple Ford White Bear Lake
$258.72 for a factory 3.0L Intercooler. That's our cost, Ford obviously is making money off of that, so their cost is probably less than half of that from a manufacturing side.
Compare that to aftermarket Bar and Plate coolers, they range from $600 to $1,000 depending on the design and manufacturer. So you're paying 2x to 4x the cost for that added performance, but it's more than what just the raw temp numbers indicate as there are other benefits to a well-designed intercooler other than just performance.
That's why OEs dont use larger bar and plate ICs or even better tube and fin designs. It's not about raw performance, spare no expense. The OE cooler did a good job for average use cases and they rely on the tuning strategy to pull power when things heat up, but it definitely is outside of its optimal range with sustained pulls and for more extreme use cases like off-road performance driving (i.e., Ranger Ratpor Race truck even at stockpower levels).
That's why the Ranger Raptor Race truck changed out the OE intercooler for a PWR unit. It's visible in their videos when they are working on the truck and PWR is one of their sponsors (class rules allow for cooling system upgrades). So, for performance driving demands / racing, it's a very important upgrade, but even on a stock truck, from the owner perspective, I still think it's a worthwhile upgrade to enhance the consistency and turbo longevity under hard use cases, so, I disagree with others that state "it's only good for emptying your pocketbooks for daily driving".
Maybe if you ONLY drive the truck like a car / light SUV and don't do other things like tow or performance driving that is true since you're not really getting into boost much (low turbo loads) and only for short durations at higher boost where it's not really heating up the turbos, which again is the average joe use case, but I'm not your average joe, am I? :sunglasses:
So far, this has been an excellent upgrade and I'm pretty familiar with how the stock unit behaves since it's been in the truck for the last 29k miles with 24k of those miles on the Pro Cal. I do not have any plans for further power adders beyond the Pro Cal, the CP-E Delta and deployment of TriboTEX DLC films is aimed at durability / reliability / consistency in hot or worst-case conditions. The Pro Cal was the sole power adder with factory reliability and durability, all safties in place etc. The CP-E Delta and DLC films are durability enhancements to off-set some of the additional wear / thermal stresses from the Pro Cal to maintain near stock-like reliability at the higher power output.
I call this the Ford Performance Trifecta as it balances performance with durability, reliability and endurance under hard use while preserving stock fuel economy when you're just driving around normally. A truly "do it all" setup. It's good enough power wise, time to just enjoy driving the truck more! next is tires, but I have to decide whether to stay with 33's and go Pirelli XTM due to their size availability limits or go with skinny KO3's in 35x11.5's and a 1" front lift / aggressive fender trimming for a more race truck take on larger tires (keeping the CG as close to stock as possible, so minimal lift), but I got time for that one.
dingleberry
Bellingham
Ranger raptor
Not to beat a dead horse here, but also considering some upgrades with the IC & pipes.
Based on looking through this forum, top 3 ICs are cobb, turbosmart, & Wagner. Cobb and turbosmart seem pretty similar in price and install... Wagner retains the rear shutter shroud but needs cutting and some miscellaneous trimming... anyone have some hard opinions on turbosmart or cobb?
Also, does anyone find value with changing charge pipes? Ive only seen CVF and AFE, any other considerations? Pricing between the 2 is a few hundred bucks.. any have a preference?
I did the Cvf intercooler and charge pipes and found better throttle response. I’m guessing that comes from smoother flowing air and rigid pipes that don’t flex under pressure/ vacuum
