dpAtlanta
Just North of Atlanta
I have always wondered just how far away I am from what the rear camera is warning me about.
Green/Yellow/Red... okay, but what is the actual distance?
I actually measured from the receiver, since that is what will contact first.
The first lines are the green ones:
Ford Ranger Rear camera / parking sensors distance measured IMG_6731
Ford Ranger Rear camera / parking sensors distance measured IMG_6732
Distance to the receiver: 5.5 feet
Ford Ranger Rear camera / parking sensors distance measured IMG_6733
Now the Yellow lines.
Ford Ranger Rear camera / parking sensors distance measured IMG_6728
Ford Ranger Rear camera / parking sensors distance measured IMG_6729
Distance to the receiver 3 feet.
Ford Ranger Rear camera / parking sensors distance measured IMG_6730
Then we get to the Red lines.
Ford Ranger Rear camera / parking sensors distance measured IMG_6725
Distance to the receiver 15 inches
Ford Ranger Rear camera / parking sensors distance measured IMG_6726
Useless thread... but I have always wondered.
CaptAngry
Denver, CO
2026 RRaptor
Space Engineer
Not useless… interesting. I’ll promptly forget, but thanks for making the effort!
dpAtlanta
dpAtlanta
When you puncture a square hole into something, you will promptly remember.
bigb
Tucson
2025 Ranger 2.7
Thanks for that info, it is useful and I had not measured it yet. I will try and remember it by 6-3-1.
I will add that when the beeping turns solid you are a foot away from an obstacle, which is too much IMHO, I wish it would not turn solid till you are 4-6" away. My Superduty didn't turn solid till about 4" and it was handy for the tight quarters I have on my property. When it turns solid at a foot, you have no idea how much more you have because the tone is solid from 1 foot to zero, so that is essentially a blind guess zone.
I also figured, as near as I can tell, that the dotted lines on the sides of the 360 bird's eye view are about 12" from the stock tires.
Wallowa Ranger
Eastern Oregon, USA
'24 Ranger XLT Sport 4x4 w/ Adv. Tow & Tech Pkg.
Interesting to see this measure. Now I wonder if its the same with all Ford models. Would someone be able to test with another Ford vehicle and see if the measurements are close to the same?
dpAtlanta
dpAtlanta
I just noticed a mistake in your first measurement, 66" = 5.5 feet, not 6.5
Good catch... I edited it.
Thank You.
dpAtlanta
dpAtlanta
I did the same on my 2024 Bronco... same distances from the rear mounted spare.
LeeHo
Lee
Niles, Mi.
Got it! 18" - 👌
I always wondered about this
snowman3
us
none
An easy wat to remeber is the first one is 6ft (about), then halve it , (3ft), then halve it again (18in), not precise but easy to remeber.
interesting how brains work!. i count down by 2; 5-3-1. real distance is a bit bigger, gives some wiggle room.
snowman3
us
none
Thanks OP! how close till the brakes come on and stop the back up? (If you trust it). I'm not 100% sure, but i thought it would slam on brakes last second before hit wall. Anyone know if that true? Maybe speed dependent?
bigb
Tucson
2025 Ranger 2.7
Anyone remember
I don't think the brakes will come on if you are going slow, I think that only works at higher speeds but I could be wrong
