Recovery Gear
ozraptor
Jarel
Australia
2023 Ranger Raptor
Lots of great suggestions already. I'll add my 2c since I've built out my kit over the last year for the RR as well.
1. Try to keep your kit light. These RRs hit their weight limit fast, and the more weight you add, the worse it'll handle the type of driving it was designed for (then you'll want other upgrades).
2. Emergency essentials like good quality first aid kit, fire extinguisher, etc. Ideally sat comms like a Garmin Inreach (nice insurance, but it has nearly saved me in a bushfire situation and almost needed it from an axe slip mishap, so when things go wrong you'll be glad you have it). My first aid kits are one of the most used on group outings (I pack mine with additional basic meds as well).
3. In addition to inflation/deflation, a tire repair kit is essential. The RR has a spare, but it's a lot easier and safer patching a hole on a steep trail than changing a tire. I think a 4x4 specific repair kit is worth it too. The number of sidewall punctures I've seen in just the last year has surprised me (from sticks, rocks, and scrap in mud holes people can't see).
- These guys have great kits: https://www.gluetread.com.au
- I went with Apex Designs RCVs for fast deflation (these are awesome; 45 seconds to go from highway to 20 psi on trail and inflation is a bit faster as well). I went with the MorrFlate Tensix and 4 tire hose kit. Just make sure you pick one with good quality hoses. Cheap ones will break eventually from repeated heat cycles and use. For how often I deflate/inflate, I think this is my most used kit and worth the cost. I also ran 4 awg power into the tub (hooked up to an Aux switch) so it's a lot faster than having to pop the hood, connect the compressor, etc. Having said that, when I'm solo it's great but with friends you end up standing around waiting anyway. If you want a starter compressor before going full kit, I can second the Milwaukee. I started with their M18 and it works great (obviously slower than a high power 4 hose kit, but an easy, reliable way to get started, esp. if you already have one of their batteries).
4. These are more capable than I think many people assume (at least where I live). I went out and bought a bunch of kit (4 traction boards, ropes, high-lift jack, etc) and I haven't needed it for myself yet (been through mud, snow, rocks, etc). It'll happen eventually, but I've needed a lot less than I thought I would (everyone's recommendations fit well here - at least basic tools, shovel, etc). -- And on that note, I do not recommend buying some other sort of jack, especially a high-lift. It'll be unnecessary dead weight. When you get enough 4x4 experience you'll know when it's time to add something like this.
5. I highly recommend using/checking your kit regularly. The moment you buy it, open it and figure it out, and then regularly check and inspect everything after that. The number of people I've seen in just a year pull something out they've never used and find out it doesn't work or fit, then they're going around camp asking for help or waiting for someone to come by on a trail. Tools are a great example here; people buy car kits and then find out they don't have something specific to their rig. I use the tools I keep in the truck for my general maintenance, which has been a great way to make sure I've got everything I need and it's working correctly.
Congrats on the RR! You made a great choice. It'll be a blast! :)
Ron Quixote
America
Several
πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†πŸ‘†
purdyd
california
Lots of good advice above. Been off-roading for fifteen years.
Personally, my kit has gotten simpler and lighter as I’ve learned what works and what is just extra weight.
Jack base (yes, I just carry the scissor jack; bottle jacks have to remain upright or they leak and floor jacks don’t travel well)
I think the scissor jack is ok. One of the first things I did was jack up my truck with it and lower the rear tire.
i had a Toyota Hilux and that jack didn’t go high enough,
i do carry a poor man’s jack base, aka chunk of wood for soft ground
BC_Blue
Dan
British Columbia, Canada
2024 XLT FX4
Lots of good suggestions here. Not sure what your budget is like, but check reviews and try to stick to reputable brands - don't want something to fail when you really need it.
One addition - for national forests, folding saws pack away to nothing and are good for clearing debris.
Start small, see what you need. Especially if you are wheeling solo, the best thing you can do is stop, walk an obstacle to assess, and don't be afraid to back out and pick a different trail.
Glisch
Houston, Tx
So Just wanted to know if the brand Bubba Rope is a solid choice? There have a 25% off coupon that expires today.
They are awesome. Watch some Matt's Offroad Recovery videos to see them in use.
Unless I'm going somewhere I expect to use it, I leave it in the garage though. It takes up a HUGE amount of space. The ARB kenetic strap isn't quite "as good", but it takes up 25% of the room in the truck, so I carry that for most adventures.
jordantii
jordantii
Jordan
Tampa Bay
www.straptacademy.com
2025 RR
I have watched him. I thought he used Yankum ropes? Either way, USA made and what I consider a reasonable price shipped to my door.
Glisch
Houston, Tx
Oops, you're right. I have the yankum, not the bubba. I got them confused. Project Farm also has a video on these!
I go the following for recovery:
ARB 4x4 Accessories Snatch Strap 17,500lb ARB705LB ARB705LB
ARB 4x4 Accessories Soft Connect Shackle ARB2018 ARB2018
ARB 4x4 Accessories Recovery Bow Shackle 19mm 4.75T Rated, Pin size 23mm, Type S ARB2014 ARB2014
Bow Shackle on one end, the soft connect on the other, soft connect acts like a fuse, if something is going to exceed the tensile strength, the soft shackle will break before anything else. Throw a towell / blanket / coat on the tow line so it doesn't whip back into your windshield, plus with the soft shackle, it's all rope, no metal to go flying into anyone (better safety).
The raptor empty is about 5,300 lbs, so the ARB snatch strap and soft shackle are rated at about 3x vehicle weight unless you're pulling someone out with a really heavy rig (like an overlanding F-150 Raptor on 37's with 1k lbs of gear / passengers).
As others have said, basics, shovel is lightweight and very helpful to just use stuff you find around you like stacking rocks under a stuck tire, could lift the truck up a bit with a scissors jack, then put some rocks under the tire(s) for traction.
Lighter weight is better, vehicle is more maneuverable, less likely to sink down in soft terrain and easier to pull out than something super over loaded. Plus, the Raptor's bread and butter isn't level 10 hard core rock crawling trails, it's high speed in the desert, dirt roads, sand dunes or even prepped tracks etc. Everyone has different uses, but I'm keeping mind more performance oriented than hard core 4x4, the most I'll do is probably level 5 or 6 trails, something a stock RR could do and that's the vast majority of trails, 1-5 (out of 10) difficulty rating.
Also a block of wood for the jack base is a good idea, especially in soft terrain. Tire inflation / deflation is another good area to spend money on to get something that works well and is reliable. I also really like the idea of tire repair kit as an option to avoid changing to the spare until you can get on-road, if that gets you somewhere easier and safer to jack up the truck (flat, level and hard terrain), I'd do the repair, get to safer area, then swap out the damaged tire for the spare.
I got Method 705's and did all 5 wheels, so my spare is a 705 since they have different weight / off-set than factory and I wanted proper on-road handling just in case I needed to drive a good distance to get back home on the spare.
I don't have any yet, but plan to eventually get some, traction boards are good for loose terrain (sand, gravel, mud with a rocky bottom). They are lightweight too. For securing said items, I'm putting in L-Track system in the bed (4x 4-foot rails), so most of this stuff can be secured with a very light weight system with straps.
48" Aluminum L-Track | Black Anodized Finish
Those 4 foot strips are only 1.5lbs of added weight, so 6lbs + some screws, you can strap in anything, plastic totes from Home Depot, tractions boards, 5 gallon marine style lay-down gas tanks, shovels etc. I think that's the way to go vs. all these bulky racks etc. that add 150~200 lbs not even counting the gear itself and cost thousands of dollars, so air-craft style L-track + factory tie downs will do a LOT for you, cheaply and at almost zero weight penalty. Plus, the L-track is very utilitarian for Home Depot runs or even strapping big duffle bags, tents and other things in bed for practical uses like home repair or just taking the family to a campground.
Weight adds up super-fast, so be systematic and take the "race car / cargo plane approach", IS THE WEIGHT really worth the pull? 95% of the time, a recovery strap and a buddy will do the job, other 4.9% of the time, a shovel, traction boards or spare tire / patch kit will do the trick. And 0.1% you might need a winch or high lift jack if your solo on a level 7-10 trail, but I'm not doing that, so just not worth the cost in performance / literal cost for me personally or most people. Plus, you can end up in a situation where there's nothing to attach the winch too!
Sometimes, less is actually more.
BTW, I had a buddy come with me that fell for some B.S. on a mud-pit back in the woods at the OHV park we went to. Some guy said, "yah you can do that with a stock Wrangler", he had a 2011 Sahara, capable but nothing amazing by any means. No locking diffs, I think 31" or 32" road focused AT tires, 4-door, no lift.
Come to find out, one of the grounds keepers had a stretched Rubicon on 40" tires with two winches and HE GOT STUCK in that mud pit it was that bad, had to pull himself out, he just laughed at my buddy who fell for it.
We found that out AFTER my buddy tried to go into it with his stock sahara....ROFL! He ended up high centered on a big rock that was obscured, no shovel, traction boards would have worked. He could barely get out of the Jeep because the mud was so deep.
But a good old 30-foot tow strap and another vehicle towed him right out (I was not nearby when it happened). A rear-facing winch could have gotten him out maybe, but there weren't any trees ideally in the tow path and most of the bigger ones were over 50 feet away...but another truck and a $75 tow line? Yah, it works.
Having a travel buddy and a tow strap is worth more than all the other equipment combined 100x over.
