a77cj7
Chris
Sturgis, SD
98 Ranger
My fiance and I attended the first Ranger Raptor Assault class last week. It was a great time, and she learned quite a bit. We turned the trip in to a week long road trip, visiting fun areas along the way.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0853
Front of facility
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0857
Class trucks in background. We had #2.
After the class was complete, we went to moab for a few days, and explored a variety of trails.
I purchased the book “Guide to Moab, UT Backroads and 4-Wheel-Drive Trails” from Amazon before our trip, and would highly recommend it for off road adventures in Moab.
https://www.amazon.com/guide-backro...1719546472&sprefix=moab+backro,aps,201&sr=8-1
After arriving the first afternoon, we took a “easy” trail called Potash Road and Shafer Switchbacks. It was a great scenic drive with many overlooks into the canyon, and a narrow climb up the mesa to Islands in the Sky at the end.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0865
Near beginning of trail.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0869
Potash road view
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0874
Potash ponds
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0882
Overlook over Colorado River
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0878
Overlook
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0884
View from road.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0890
Switchbacks
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0894
Switchbacks
We started early the next morning to get into Arches National Park before 7am to avoid needing a reservation. We used the backcountry “Willow Springs Road” to get in, another “easy” trail.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0910
We stayed on pavement for awhile after reaching the main park road, and did some of the short hikes to arches.
Next, we ran the Tower Arch trail to tower arch and eye of the whale. This trail is mostly “moderate”, but does have a “hard” section toward the start. It rained while we were on trail, so some of the washes were running mildly. I picked up a trail pinstripe down the rear passenger door and fender, neither of us heard it happen. Suspect a juniper tree. It should buff out fairly easily.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0938
Hard section
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0943
Flood, waited 15 min till the level was much lower to proceed.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0949
Tailgate lunch stop near eye of the whale.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0961
Eye of the whale.
We made it back to Moab around 2pm, then headed out to Sand Flats to run Hells Revenge trail. Hells Revenge is a bit much for a stock ranger raptor, but is doable without damage with a competent driver and spotter.
My truck is stock except for 2” foutz lift collars on the front. I also ran a receiver hitch skid plate on the rear, as i knew the departure angle wasn’t sufficient.
We ran alone and spotterless, and I did pick up a scrape in the coating on my passenger running board when I misjudged a line and turned into a rock.
This should have been the only trail damage suffered if things had gone to plan. The weather had other ideas. We noticed dark clouds rolling in while at the farthest overlook, but had no service to check weather. We got service just before the storm hit, to discover it was a severe thunderstorm with half dollar sized hail and 70mph winds. I found a flat spot with no drainage above, and we rode out the storm waiting for the truck totaling hail. Luckily it never came, with only some pea sized. There was multiple inches of rain and massive winds for 15 minutes or so.
After the storm passed, I consulted the guidebook and noticed the entrance/exit is called “Lake Michigan”, and noted to be usually dry but very deep after rains. I took this to mean impassable, so I abandoned the plan to return that route and took the other exit.
The book noted the exit to be rough and relentless. It was all of that, and exceptionally brutal for a stock ranger raptor. The slickrock gives way to more conventional cobbles and boulders, and high clearance is needed.
I fell off a few lines, and suffered two mildly scuffed wheels, more coating damage to the passenger running board, scuffed and dented drivers exhaust tip, mildly scuffed passenger exhaust tip, and several dings on the front skid plate.
All cosmetic and minor, but far more damage than I intended for the trip.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0976
On top of mini lion’s back, trail entrance.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0977
Lake michigan, before rain.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0978
Trail
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0979
Typical climb on trail.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0980
Trail
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0984
Overlook
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0981
Overlook with impending storm
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0989
Rainbow after storm ended.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0992
Mickey’s hot tub. Filled by storm.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0993
More typical terrain
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0994
View from trail
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_0997
Only photo of exit road I have, a very easy section. I stopped taking photos as I was completely over it and mad about damage truck was taking every obstacle.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1001
Flooding in Moab from storm.
EDIT: Adding more.
The next morning, we headed back to Islands in the Sky on pavement and did touristy stuff, overlooks and short hikes.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1007
View through Mesa Arch
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1017
Overlook view, part of White Rim trail visible.
We returned to Moab for lunch, then it was time to head home. Our next hotel was only a few hours away in Parachute, CO, so we decided to depart the fun and scenic way by backroads.
We returned to sand flats, and took the sand flat road and headed for the La Sal Mountain Loop. Sand flat road is usually a well maintained gravel road, but had heavy damage from the storm. It was still easily passable, but much rougher. Once we reached the national forest, the gps suggested a shortcut on forest road 4634. I was planning to stay on Sand Flat Rd, but when we reached the intersection, discovered that 4634 was a moderate to hard off road trail that started with a rock ledge, then a steep rutted climb. We decided we were up for one more adventure, and proceeded that route. Trail was very narrow between tree branches, which limited line choices to avoid more trail pinstripes. Made it through with no undercarriage scrapes, tires at full 39psi. Trail came out right next to La Sal overlook.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1031
Storm damage on sand flats
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1032
4634 Trail
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1033
Views from 4634 trail
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1037
La Sal overlook
From La Sal road, gps directed us back toward Moab and up to I70 to head to Grand Junction, co. However, the sign at the T said gateway, Colorado was the other way. After telling the gps to go to gateway, it agreed. Started out as an old paved/blotter road with no pavement markings. Quickly turned to well maintained gravel, then minimal maintenance gravel/dirt. Only signage at colorado border was a “no winter maintenance” sign. It was a fun, scenic trail through the mountains, and an excellent way to finish up the off road portion of our vacation.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1039
Switchbacks on La Sal Mountain Loop
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1040
Views on trail to gateway.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1041
Trail to gateway.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1044
Trail to gateway.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1047
Road down canyon from gateway to grand junction.
My only real regret, other than the damage suffered on the hells revenge exit road, was not having more time in Moab.
Specifically, I would have liked a full day to run the White Rim trail, and another to tackle Fins and Things. Maybe another trip in the future, plus visit more of Utah’s parks.
Vel0ci
IA
Nice write up. Did you use the lockers or it wasn’t necessary?
OH3Cobra
JP
Indy
Sales
incredible. thanks for sharing
a77cj7
Chris
Sturgis, SD
98 Ranger
Lockers were absolutely needed for Hells Revenge. I was aired down to 14 front, 12 rear, ran the whole trail in rock crawl mode, low range. Rear locker on the whole time unless tight turning needed, front turned on when I needed a front tire to climb a rock/ledge independently.
This brings up my one complaint of the truck, the shifting in low range, specifically 1-2. It is way too hard at part throttle, and causes the truck to jump forward violently. It was a minor annoyance at raptor assault, but straight dangerous on Hells Revenge. I ran in manual mode, and was yelling at truck every time i shifted to park or reverse then forgot to hit the manual button and it jumped.
For the other trails, I used low range a few times to crawl stuff and keep abuse down, but never needed lockers. (Rear comes on automatically in rock crawl, never turned it off unless turning sharp)
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
https://www.amazon.com/guide-backroads-trails-FunTreks-Guidebooks/dp/1934838292/ref=mp_s_a_1_1?crid=34DUAV9238VO4&dib=eyJ2IjoiMSJ9.kr8Uy-jKnDPozjx_iphhkEzV1CJN3L501egknDy1scy7miyWqE7HTbl4jERb8tyQBjpkMArllv4Dzn5-hnmmSdvZ98UserFrKXpyiRjW6oTqOm5rabZvwA4rznd4ctff1ycWBUdIU-v6wsKLotJ6P8wpIQ4JjKn6iyObm2YEdtPh2Ms4P9BaDNOAQeK1EDTTUic39bwiykLqKd4B-1PsLQ.DGlXVsBo1Gpt0olsD3zdiV9wiFn-Ff5coZcGDEVUGW4&dib_tag=se&keywords=moab+backroads+book&qid=1719546472&sprefix=moab+backro,aps,201&sr=8-1
Switchbacks
Hard section
Eye of the whale.
We made it back to Moab around 2pm, then headed out to Sand Hollow to run Hells Revenge trail. Hells Revenge is a bit much for a stock ranger raptor, but is doable without damage with a competent driver and spotter.
Overlook with storm approaching.
Amazing photos, thanks for sharing!
ShadeTree
Barry
Republic of Texas
2024 Ranger Raptor, 2016 Wrangler Rubicon, 1947 Willys CJ2A
engineer
Excellent post! I've taken my Jeep to Moab and done Moab Rim and Hell's Revenge. I wouldn't dream of taking my pretty new truck on the rim for sure and I doubt I would take it on HR, though it is milder. Good for you, but I'll pass.
a77cj7
Chris
Sturgis, SD
98 Ranger
More pics added throughout. I don’t have pics of many of the best obstacles as I was concentrating fully on picking lines and driving.
a77cj7
Chris
Sturgis, SD
98 Ranger
Yeah, it was a hard decision. But I never made it to Moab with my Jeep, and expect these world famous trails to get closed in the future. (I hope I’m wrong there.) The running board scrape on trail didn’t really bother me, just a mistake I made. The continuous hits on the exit road were awful though, I was not having fun at all.
After the pain subsides, maybe I’ll make it back to run the slightly milder Fins and Things someday. White rim too, but would expect no damage potential there.
I’m going to try the cheap method of repair first, i have a can of two part raptor liner for the running board, and some magnetic gray paint for the wheels. If this turns out unsatisfactory, I will buy two new wheels and try to buy running boards from one of the forum members who was taken them off.
I’m unsure on the exhaust tips, maybe a magnaflow cat back when released? Maybe the aussie 4” black turndowns? Maybe just polish and call it a trail badge.
Top Fuel Friday
Kentucky
24' Ranger Raptor, '22 GT500, '21 Diesel Wrangler
Awesome trip and photos, I remember doing that second part of Hills revenge in my diesel wrangler on 37s with a 3 inch lift, it was fucking brutal.
pablo94sc
Focus
Nice photos and fun trip. I only did the hard part of Steel Bender while out there, and that was plenty for my trip. Shafer is amazing. Glad you got to experience that!
MAV
Arkansas
Great photos and write up! Got any pics of the damage? Those would be good to help understand where the some of the common points of risk are on the truck.
a77cj7
Chris
Sturgis, SD
98 Ranger
Yeah, I’m gonna put my mudflaps on this afternoon before some high speed gravel running, so I can snap pics of my mistakes. All are vulnerabilities i had identified ahead of time, no surprises.
swisher_jones
Los Angeles, CA
Great write up and pics, glad I saw this before making the drive up to the Assault class from LA later this year - was thinking of doing a similar trip but will think twice about some of the extra stops I make along the way.
a77cj7
Chris
Sturgis, SD
98 Ranger
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1072
Passenger front wheel
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1069
Driver rear wheel.
The heavy offset and spoke design causes the spokes to sit outside of the tire’s protection. +30 wheels would help considerably.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1071
Passenger running board. Smaller rear scuff is trail mistake. Much heavier front scuff is falling off line on exit road.
Running boards hang low and stick out side. Much rather sacrifice running board than rocker or door. Replace with frame mounted sliders for wheeling build.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1070
Drivers side exhaust tip. Thanks exit road.
Hard to protect these on wheeling truck, probably go to dumps behind rear axle with heavy steel rear bumper.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1076
Scuffs on front skid, doing its job. Wheeling build replace with heavy winch bumper and thicker skid.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1074
Hitch skid. Did its job well.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1075
Hitch skid installed. Messes with parking sensors but great on trail.
Ford Ranger Ranger Raptor in Moab and Hells Revenge IMG_1073
Trail pinstripe picked up on tower arch trail. Didn’t hear it happen. Doesn’t catch fingernail, expect to easily sand out of clear coat.
I’m not building a wheeling rig out if this one, and intend to never take it on a trail this hard again. I will add better underbody skids as they become available though, and an arb summit front bumper (deer).
