RRW Wheels
patc890
Patrick
Rockville, MD
+25 offset
Very nice. I just got a set(matte bronze) from them. Did you use OEM TPMS? Their site says it works on their wheel with an adaptor. I've written to ask exactly what that is.
darceydo
FTL
Here you go...
Wheels: RRW RR7-H, +25mm, 17x8.5, Machined Finish with V2 Black Rings (on backorder)
Tires: Falken Wildpeak R/T01, 35x11.5x17, Load Range C
Lift: Hyperco Coils, 2.25" Front, 1" Rear (3/4" or rake)
Tire and wheel combo weighs .04 pound more than stock. :sunglasses: I do not notice any loss in power. Truck still gets up and goes just like before.
Alignment specs are dead on. No need for aftermarket UCA's. Used Forscan to reset the ride height sensors and program the 35" tire size.
Rides much firmer, but hoping the springs settle and the Live Valve learns. I need to play with tire pressure a little too, which will help the firmness.
Debating this exact wheel setup for my Desert Sand RR but cant picture how it will look on the aluminum
RaptrJr
FL
I used the OEM TPMS. Didnt have any issues to my knowledge
kevinL
Western PA
2025 Ranger Raptor, 2018 C43 AMG
Hey guys, for those of you who've been running RRW, did you end up going with lug centric installation with the lugs RRW sells on their site? Are you running into any issues with the hub size mismatch with it being too small of a difference to use centring rings?
Slyder
Washington
KTM 1290R, '24 Ranger Raptor
Machinist
I'm using the RRW lugnuts with my wheels and have had zero issues so far.
patc890
Patrick
Rockville, MD
I just got my RRW wheel but haven't put them on yet. I did buy the lug nuts they sell also. On their web page it says when you get their lug nuts "the wheels are now not only hub-centric, but also lug centric."
MidnightSpecial
2025 Raptor Ranger
I have the monoforged. TBH, I would go cast unless you are planning on abusing the hell out of them. The weight difference is pretty negligible. I think my monoforged were ~27lbs each which is pretty close to their cast versions.
Ford Ranger RRW Wheels PXL_20250412_160651139
Ford Ranger RRW Wheels dji_mimo_20250412_092130_0_1744478798914_photo-2
Ford Ranger RRW Wheels PXL_20250427_182310359.PORTRAIT
Ford Ranger RRW Wheels PXL_20250524_142713562
Slyder
Washington
Machinist
The Flowformed and Monoforged are pretty close in weight for most styles. The main advantage the Monoforged have is they're stronger and will tolerate more offroad abuse.
MidnightSpecial
2025 Raptor Ranger
Yep, thats what I was talking to in my sentence. Most people probably won't need the strength. Most people associate monoforged with being lighter. Was just wanting to help anyone that is making a choice based on weight for performance.
patc890
Patrick
Rockville, MD
I just had my RRW wheels put on. I used the original tires. They are 17x8.5 | 6x139.7 | +25 | 5.73. They used the OEM TPMS but had to change the valve stems.
A few photos.
Ford Ranger RRW Wheels IMG_2201
Ford Ranger RRW Wheels IMG_2203
Ford Ranger RRW Wheels IMG_2206
Ford Ranger RRW Wheels IMG_2204
Ford Ranger RRW Wheels IMG_2202
DesertSolitaire0928
Christian
Santa Fe, NM
24 Ranger Raptor Azure Grey
Ordered the RR7-H 17x8.5 | 6x139.7 | +25 | 5.73 for my 24’ RR
Based on previous comments, I think the OEM TPMS should work
As far as new valve/stems, was thinking of going with Apex Designs Rapid Precision Valve…they have two lengths; STD vs XL.
is anyone running these Apex RPV’s on their Race Relations RR7’s?
RRW website doesn’t publish the valve recess/valve stem well depth specs.
Apparently STD is for <0.6” depth
Whereas XL is for ~0.9”
Wish I could call RRW but I suppose I’ll email their customer support
donkey
California
A few photos.
Can you please take a picture from the back so I can see how the mudflap centers up?
