Suspension temperature calibration procedure?
Klutch
Cole
Saskatchewan
I thought i'd make a post of it's own on this, does anyne know how to do this. Circled in red on pic
Ford Ranger Suspension temperature calibration procedure? 20250303_185401
ag02m5
Google
In for updates as I did the suspension adjustment with ET mode but not this.
Would love to get mine back to 0mm instead of the current 2mm all around.
pasali
Paul
Livermore CA
Carpenter
Is this a forscan thing? I just did a lift/level kit and even though my shop told me they would take care of re-setting the shock sensors with forscan after installation, they fired the only guy they had that knew how to do it. I was wondering if there’s a way to reset ride height without forscan? Thanks.​
Klutch
Cole
Saskatchewan
Yes forscan is the only way I know how.
Antman450
Anthony
Reno, NV
2024 Ford Ranger Lariat
Anyone know the procedure for doing this via Forscan? I did the suspension levelling reset, but had not heard of a temperature reset.
TheRealSasquatch
Bronco
I believe you have to unplug one position sensor while in Forescan and the calibration will be prompted. I saw this somewhere on YouTube. Searching now. Will update post.
Similar For Bronco Raptor:
Bronco Raptor Live Valve Calibration.
Klutch
Cole
Saskatchewan
This video is showing what to do if VDM doesn't appear in your forscan menu. Still wondering what the temperature calibration is.
TheRealSasquatch
Bronco
Have you tried entering the Engineering Test Mode detailed below your circled text to see if there is a function in that mode?
TheRealSasquatch
Bronco
Yeah did that too. Still haven't seen anything.
Hmmm I wonder if it’s something buried in Ford Diagnostic software that Forescan merely emulates.
I tried googling a bunch of word combinations that could reference that calibration procedure and didn’t come up with anything.
do we know if there are temperature probes / sensors on our shocks or is it referencing something else in another system. I’m not a Canbus specialist so I don’t know how to access that stuff.
Would Fox be able to tell us? Do they have technical support?
Klutch
Cole
Saskatchewan
This is what I get when I do as described in forscan..
Ford Ranger Suspension temperature calibration procedure? 20250419_082939
Kit2523
Kit
Phuket,Thailand
2023 Ford Ranger Raptor V6 Ecoboost
I also had 7mm (0.28 in) on all four corner after Ride Height Calibration too. The gas tank was 1/4 full. Was your tank 1/4 full also?
Klutch
Cole
Saskatchewan
I think it was. I've calibrated many times with different tank levels, and I always get a number on all four corners other than 0.
