- Joined
- May 16, 2024
- Threads
- 10
- Messages
- 693
- Reaction score
- 1,125
- Location
- Lake Ontario
- Vehicle(s)
- 2024 Ranger Lariat FX4
My Ranger plays FLAC files. Everything else is secondary.
So one wants Sync4 NOT Sunc4A....?
Feature SYNC 4 SYNC 4A Verification Method Cloud-Based Navigation (Waze/Google Maps integration) Yes (via Ford+Alexa or embedded Waze)
No — only offline map data (HERE Maps)
Check Settings > Navigation > Map Updates: SYNC 4 shows "Cloud Map Updates" toggle; SYNC 4A shows only "Update Maps" button Over-the-Air (OTA) Software Updates Yes (automatic & manual, up to 3 GB)
No — requires dealer visit or USB update
Settings > System > Software Update: SYNC 4 displays "Check for Updates" + "Update Available" status; SYNC 4A shows grayed-out option Voice Assistant Capabilities Natural language, multi-step commands (e.g., "Find charging stations near my route and reserve one")
Limited command set (e.g., "Call Mom", "Tune to FM 98.7") — no contextual awareness
Press and hold voice button, say "What can I say?" — SYNC 4 responds with full command list; SYNC 4A gives abbreviated prompts Customizable Home Screen Widgets Up to 8 resizable widgets (climate, audio, navigation, phone, etc.)
Yes — same UI layout, but fewer supported widget types (no EV charge scheduler or trailer brake controller)
Long-press home screen > Edit — SYNC 4 offers "Add Widget" with 12 options; SYNC 4A shows 7 Wireless Apple CarPlay / Android Auto Yes (standard)
Yes (standard on 2023+ models; optional USB-only on 2021–2022)
Connect phone without cable — if wireless pairing succeeds within 15 sec, it’s enabled. Check Settings > Connectivity > Wireless Projection
So '4' is an older version and 'A' is newer with less features??? Typical Ford.
Im fairly certain this is patently false.....So '4' is an older version and 'A' is newer with less features??? Typical Ford.
| Platform | Core software stack | Screen layout | Data capability | Phone mirroring | Where it shows up (2025–2026) |
| SYNC 3 | QNX legacy | Small landscape | 3G/4G, limited OTA | Wired | Older carryover models, used market |
| SYNC 4 | Ford QNX | Medium/large landscape | 4G LTE cloud-connected | Wireless | Many 2021–2024 trucks and SUVs |
| SYNC 4A | Ford QNX with dash cards | Tall portrait | 4G LTE, richer UI | Wireless | Mach E, select specialty lines |
| SYNC 5 | High-power Ford platform | Large landscape | 5G ready | Wireless | Select 2025–2026 F-150, Mach E |
| Ford Digital Experience | Android Automotive OS | Multi screen, cluster linked | 5G integrated | Wireless + native apps | 2025 Expedition, 2026 Explorer |
as far as I can tell there is no sync 5 and the f150 2025 and 2026 has sync 4This seems to be more accurate as of function, note it does note the horizonal/vertical as many have said but with other changes as well.
Platform Core software stack Screen layout Data capability Phone mirroring Where it shows up (2025–2026) SYNC 3 QNX legacy Small landscape 3G/4G, limited OTA Wired Older carryover models, used market SYNC 4 Ford QNX Medium/large landscape 4G LTE cloud-connected Wireless Many 2021–2024 trucks and SUVs SYNC 4A Ford QNX with dash cards Tall portrait 4G LTE, richer UI Wireless Mach E, select specialty lines SYNC 5 High-power Ford platform Large landscape 5G ready Wireless Select 2025–2026 F-150, Mach E Ford Digital Experience Android Automotive OS Multi screen, cluster linked 5G integrated Wireless + native apps 2025 Expedition, 2026 Explorer
