White willy
Earth
2025 Ranger
Thinking of using this bracket to mount my WOLF BOX mirror to get rid of he mess
And which bracket would that be?
I am in need of something to do the same.Any info would be greatly appreciated!
ndtx06
Eric
Ranger Raptor 2024
Thanks to the heads-up by @bdallas9 I was able to get in on the pre-order of the new TackForm TRAXX dash mount system and unlike a lot of other pre-orders, it actually arrived early. I chose the Slim Track option and picked up a mag mount for a radar detector initially with one of their blue anodized thumb knobs.
The parts all came well packaged and nicely organized (and did I mention early). They amazingly include almost everything you need to install other than a small drill and a Phillips screwdriver. I was especially impressed that the mount is entirely aluminum, including the formed "wings" which I really expected to be plastic.
The end result is super clean and seems very sturdy. So far I only have my trailer TPMS display mounted and I am going to be getting a different arm setup to reposition it better along with a GoPro mount just because.
For anyone interested in the actual install process I made a video:
Pretty simple install all of the parts fit and instructions were clear. Hardest part was the rail install. Found it was easy to thread one of the center bolts and pull up on the rail and thread the others with one bolt slightly tight.
Good job TrackForm.
Ford Ranger Tackform TRAXX Dash Mount Install IMG_9650
nicpie
Nicholas
San Diego, CA
2025 Azure Grey Ranger Raptor
Construction
Just got my tackform mount installed yesterday….with a few small hiccups.
Found one of the bolt holes for the track mount in the dash mount base to be stripped. Waiting on response from tackform on replacing.
I ended up fumbling a screw and it slipped through the control unit vent right above the dash mount. Heard it trickle down through the dash :( Any insight where it might have ended up and if how I’d retrieve it without taking the whole dash apart? ? I’ll be investing in a snake cam to start the investigation haha
Either way loving the set up so far with my Rokform case mounting system and making due with 4 bolts in the 4 good threads?
Ford Ranger Tackform TRAXX Dash Mount Install IMG_4095
Ford Ranger Tackform TRAXX Dash Mount Install IMG_4096
Ford Ranger Tackform TRAXX Dash Mount Install image1
Ford Ranger Tackform TRAXX Dash Mount Install image0
ndtx06
Eric
Ranger Raptor 2024
HAHA I had a bolt fall down behind screen also, heard it hit bottom. I convinced myself to say goodbye forever and removed it from my mind. Then I noticed they gave us and extra screw.....and said to myself they also had the same thing happen.
Gerry Bourret
Gerry
Indio,CA
2024 ford ranger XLT,off road and towing package
Got mine today but no TRACK with the order just the piece that installs on the dash. . Pile of shit I can't use for anything. Tapped one of the holes.They sent out a track won't get here till Monday. I'll install the mirror today. Rerouting the wires should be fun.
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0566
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0585
Gerry Bourret
Gerry
Indio,CA
This fits the aback of the wolf box mirror The one on the right has the correct ball size and a trackform extension on it this would connect to the trackform device on the dash
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0578
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0584
final using ball same sized as stock once I get my Track from mfg I'll post pictures of the install.
Gerry Bourret
Gerry
Indio,CA
This is the worst company I've dealt with in a long long time. Horrible customer service
I ordered a mount and some parts, I wish they would offer a 20 mm to 17 mm “dog bone” adapter for Garmin GPS mounts, I had to source and order one from Amazon. The problem with this method is that there are no guarantees about how well the two different parts fit together,…
Ford Ranger Tackform TRAXX Dash Mount Install IMG_8193
My DriveSmart 76 gets crazy hot from the sun and it shuts down with it mounted on a suction cup - NOT good - this will allow me to position it so that the cool air blast from an HVAC vent goes directly onto the battery area.
nicpie
Nicholas
San Diego, CA
Construction
I’d have to agree. A shame for such a great product. Still no response from them about stripped threads in the track after following up as well.
Edit: I take back all of the above. Just got a call from the owner himself and have a new track shipping out tomorrow. They should get back to you soon they’ve been traveling for trade shows. Small company but cool people. I support!
Gerry Bourret
Gerry
Indio,CA
Just got an Email slim track should be here Friday. But shipped Fedex 2nd day earliest will be Mon the 8th
Gerry Bourret
Gerry
Indio,CA
Just need to hook up the cables got too hot for my 83yr old body had to quit
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0588
el_sabio
Randall
Tennessee
24 Ranger XLT FX4
I've been very happy with this mount. In fact, it's my favorite mod so far. I, too, was really surprised and happy with the aluminum base. It's formed to look OEM. The mounts are solid and don't move. They have many many accessories for the mounts, including arms and dog bones for different size ball mounts. I highly recommend this product.
Tried to get some good detailed shots of the installed product. Again, very happy with it and will be adding more for GoPro, Garmin, etc.
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0632
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0634
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0635
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0637
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0636
Gerry Bourret
Gerry
Indio,CA
it's installed waiting for replacement bumper camera S/B here Monday. Proper orientation of mount, factory surround installed
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0612
Ford Ranger Tackform TRAXX Dash Mount Install IMG_0613
BrrRaptor
Raleigh Nc.
What size is th
E ball? I ordered one like this which was 20mm ball and was to small for the wolfbox mount. Looks like it should be 22mm?
