Tonneau cover availability
KevR
Kev
AZ
24 Ranger Raptor in AGM
Anyone try a Line-X tonneau?
CrustyNoodle
Peter
Melbourne, Australia
Mechanical Engineer
Got my cover installed yesterday and fits perfect
Can you post up some more pics? Maybe some of the internal installation and also the end of the cover near the tailgate.
We have developed a bolt-in seal kit for the 2024 Ranger so apart from being interested in the X4s for myself, I'm keen to see how it will interface with our seal kit.
SparkyTWS
Dan
Neenah, WI
2024 Ranger Lariat
N/A
I picked up the RetraxONE XR Tonneau Cover from RealTruck.com. Shipped and delivered in about 5 business days. It did have model specific instructions, and brackets for the 2024 Ranger. The clamps that I received didn't match those in the instructions, but they still worked. The only problem I ran into with the install is that the inner lip of the tailgate has an indentation and that created a gap where the closed cover would normally have a decent seal. I added some 1/2" weather stripping and it seals fine now.
GManGeno
'24 Ranger Raptor
DevOps Engineer
I am interested in the Diamondback HD which is not yet available. My thinking was this, I will not use the bed of the truck for hauling stuff, I have a utility trailer for that, so I will use the bed more as a trunk. The two lids are removable, if necessary, which will leave only the center panel. Also, the top of the cover can handle up to 1600 lbs., not planning on hauling anything that heavy, but nice to know that I could with the J-Braces installed too. It comes with a bunch of tie-down cleats. And as a bonus, if I want to trick out my cover like my truck, Diamondback has a pretty impressive selection of accessories.
So then where do I put my mountain bikes? Well, you can get a Yakima rail system specifically designed for Diamondback. Using mounting bars on a two-lid system will disallow you from using the them while your load is in place but once the load is removed, you can then operate the two lids. Meanwhile, I will be able to access my gear through the tailgate and with proper planning, the gear I may need before reaching my destination will be packed near the tailgate and the gear I won't need until I reach my destination will be in the front of the bed.
Or maybe a bed drawer system instead. Lots of options.
Paf1yyc
Calgary
Ford Ranger Tremor
My local Ford dealer in Calgary ordered a Retrax Pro XR, this came within a day with the correct brackets and was fitted. This is the same as the Ford badged accessory that is currently back ordered. Just has a Retrax badge.
Ford Ranger Tonneau cover availability IMG_5089
Ford Ranger Tonneau cover availability IMG_5090
Reactions: MJE
snowmanoz
Stewart
Portsmouth, NH
Subaru Crosstrek
Same for me. Took a bit to follow the instructions given the model specific steps but got there in the end. Will also most likely add some weather strip to the tailgate. Only issue, needed to tap a couple of threads due to spray in bed liner.
Griffy64
hanover, ma
2008 ford ranger
Hi Sparky. I installed the same cover as well. It was more of a bitch getting the measurements to be within the 1/16" they recommend. It's still not quite right. My Retrax cover was missing the casket for under the back window when it came. Had to go back to shop who sold me it. Do you have any pics of the !/2" weather stripping you added ? I had the same idea just wasn't sure it would hold up over time. The gasket on the side rails seem to keep it elevated too much or its just the way its designed. Thanks
SparkyTWS
Dan
Neenah, WI
2024 Ranger Lariat
N/A
I didn't overthink it. I just went to Menards and grabbed something that fit:
https://www.menards.com/main/hardwa...ck/52021/p-1459185067252-c-3624.htm?exp=false
(I am not an expert and make no claims that this is the best solution or even a valid one.)
Ford Ranger Tonneau cover availability coverseal_IMG_0885
Griffy64
hanover, ma
2008 ford ranger
jrRaptor
Maize, KS
I have been talking to this company in Greece. They will ship to Maine for $700 and no VAT since it’s sold outside the country. I specifically asked them if it would fit a RR2024 and they sent this link.
Here is the link with the product code that your will need:
TESS 14061 ROLL + E-KIT: https://tessera4x4.com/category/sin...lid-shutter-tessera-roll-plus-4x4-accessories
Really, really love that one but $700 for shipping = yikes lol. Looking at $3900 total. Wish this could be configured to use an aux switch to operate instead of key fob or mobile app. Love the design and lighting though.
Deleted member 7951
I just got them to use UPS and ship to Maine for $400.
I bought the manual version. I want to control the top myself.
came in from Greece in 4 days! Yahoo!
Ford Ranger Tonneau cover availability IMG_7843
Sleach
Stephen
2021 Ranger FX4
Could you post some pics of the brackets and attachments?
