Trailer Brake System Fault - anyone getting this warning?
FossIsleBC
Victoria, BC
2024 Ford Ranger XL
I tow a small (under 2,500 lbs) boat trailer - 4 pin single axle trailer and small fishing boat. No Trailer Brake System, no trailer brakes, just the factory tow hitch. Have towed the boat 2 times in the 2 months I’ve had the truck without any issue.
Today, with no trailer attached, I’m getting a warning “Trailer Brake System Fault. See Manual” every time I get in the truck and start the ignition. Six times today.
Can’t find anything in the manual. Anyone run into this? Anyone have a solution?
Ford Ranger Trailer Brake System Fault - anyone getting this warning? IMG_0619
sikedsyko
24 RRaptor, 05 Z4
I’ve seen it on my boat trailer as well. 4 pin with no brakes. Haven’t looked into it beyond seeing it a couple of times.
markal49
Mark
2024 Ranger XLT w/ FX4
Planner
Just to add fuel to the fire, I had this happen exactly once. But, if I remember correctly, I was actually towing at the time, or at least I was on a camping trip during which I towed my trailer.
I don't have a solution, but it hasn't happened again.
RangerHunt27
Louis
2024 Ranger
Possibly a blown fuse. Check I had a similar issue. Could had been when the trailer was connected it grounded out.
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
Hello, if you could send us over a message with your VIN and mileage, I would be happy to look into your trailer brake concerns.
CactusGreyFTX
Victoria BC
2024 Ford Ranger XL FTX
Well, I emailed Ford as they requested I do with my VIN. The response was less than helpful:
Thanks, Steve. Since you are reaching out to us from Canada, we recommend reaching out to our friends at Ford Canada. They will have the resources needed to best assist you! You can reach Ford Canada by phone here: 1-800-565-3673, or online at Facebook.com/FordCanada & X.com/FordCanada.
Trumeia
Ford Social Media Team
I'm not gonna go chasing help from Ford Canada - my experience in that regard is a big ZERO out of 10 in terms of the help I've received with the lack of J-Brace availability in this country for over 5 months now. That's why I came to this forum and its members for help, rather than ford. You'd think Ford on here would have known I'm in Canada since it's right there in my profile under "Location" lol
Anyone else seen this fault and have a fix? Mine's still doing it
S
markal49
Mark
Planner
I was washing my Ranger a little while ago and remembered that the one time I did get this error was after washing the truck. I assume I got water in the trailer connection and that made it go haywire. It went away after a while. I didn't happen when I washed the truck today but I was a bit more careful with pressure around the trailer connection.
FossIsleBC
Victoria, BC
2024 Ford Ranger XL
hey
thanks for taking the time to respond. I think we may have an answer here. I washed my trailer and truck when I got home from fishing now that you mention it. Quite a bit of pressure when I washed the tailgate and it happened after that. went on all day but has resolved since. Maybe moisture in the connection was the problem.
Thanks for your input!
10Ring
FL
24 XLT 4x4 Tech
Having the same problem with every startup today, the day after an offshore fishing trip.
I just aggressively hosed off the back end of my truck after having to put the boat trailer in a little deeper than usual. Up to the license plate got splashed with salt water.
I'll blast the hookup with electric contact cleaner and then stuff it with dielectric grease.
I'll report back if it fixes it.
Cabose-1
Eli
South Texas
2024 xlt 4x2, advance tow elocker
Student
Does it have anything to do with the trailer module recall? It was an over the air software update.
Check the connections under the truck and at the plug to make sure they are tight and free of debris.
