BrrRaptor
- First Name
- Scott
- Joined
- Jul 2, 2024
- Threads
- 16
- Messages
- 338
- Reaction score
- 373
- Location
- Raleigh Nc.
- Vehicle(s)
- Ranger Raptor
Got any pics of no carbon build up with CC installed?You’re missing the point regarding a Ford Ecoboost engine. Carbon buildup on the specific areas mentioned, will cause diminished performance. These are well known facts, with GDI and multi-port engines.
It’ a multi-port injected engine as previously explained. There is some fuel washing over intake valves but not enough to maintain clean valve stems. The majority of the fuel is direct injected to the cylinders. Thus, you’re going to have the majority of carbon buildup on piston crown, rings grooves and back of the TB.
Top tier fuel 91 or 93 octane isn’t going to clean GDI Injectors, piston crowns, back of throttle body and rings. Once carbon forms on these areas, you’ll start to have diminished performance and blow-by will increase as the rings aren’t able to seat completely into the piston grooves. Ford turbocharged eco boost engines as other GDI’s are notorious for this over time.
The 3.0 Is twin turbocharged and thus on boost, produces considerable blow-by.
Frankly, your tracking any car has no bearing on this discussion. I can’t speak to your comments regarding your 2.3 Ecoboost NA engine, as you haven’t provided any tangible or physical evidence in support of your comments.
I have mechanical experience and dealt with such issues, on numerous GDI and multi-port engines.
Carbon build up on GDI intake valves;
This is the ECOBOOST Induction service from BG; https://www.bgprod.com/reference/ford-3-0l-ecoboost-gdi-engines/
https://fordauthority.com/2021/07/watch-a-tech-tackle-ford-ecoboost-carbon-deposits-video/
There are many reference to Ecoboost Carbon Buildup. A simply internet search will provide them.???
