GigaRaptor
Sean
West Michigan
2024 Ford Ranger Raptor, 2020 Ford Explorer ST
Test fitted my JDScustom “Raptor” dune flag mounting bracket and installed F150LEDs.com 3 light kit.
Ford Ranger What did you do to your Ranger Raptor Today? IMG_2147
Ford Ranger What did you do to your Ranger Raptor Today? IMG_2149
Ford Ranger What did you do to your Ranger Raptor Today? IMG_4480
Ford Ranger What did you do to your Ranger Raptor Today? IMG_4478
SyphioD
Central Coast, CA
GFC Install today at Stellar Built Sacramento!
Been wondering if anyone else had a wedge camper fitted to a 2024 Ranger yet. The GFC looks great.
I am considering the Oru designs bruin but a bit concerned with how it will have straight sidewalls and a pretty large platform over the cab. For now I've got the j-braces ordered with points, probably won't move on a wedge order until closer to fall.
What I did do to my RR today is actually drive it since purchasing Friday. The excitement of owning this vehicle is finally starting to hit me after being too busy to give it any attention the past two days.
Arsenall11
Maple Valley Wa
24 Ranger Raptor
Mechanical contractor
That small detail makes a big difference, Dave! Great looking Ranger :cool:.
Thank you! I have had every generation of the F150 in Lariats going back to 86, this is by far the best built, the F-150 were all great too but the quality on this one you knocked it out of the park!
Ford Motor Company
Official Ford Account
Ford
Dearborn, MI
Ford Ranger
I finally got my new wheels!
Black Rhino Etosha wheel w/+20mm offset. The wheel fits perfectly, and as you can see from the picture with the level, the tread pattern sits almost flush with the top of the wheel arch. I also used the stock KO3 tires.
I'm so happy with it, and the bronze wheel on Cactus Gray looks sooo good!
Sweet ride! ?
welker
Scottsdale, AZ
'24 Ranger Raptor
Outlaw Jeep and Off-Road
Installed a few things this past weekend...
@GregFoutz Collars, 2.5" Fronts and 2.0" Rears. The combo worked out to right on 2.5" of actual lift in the front and about 1.25-1.5" in the rear. Truck still has about a 2" rake, which is about what I was going for so I don't sag when loaded up.
Some Baja Designs S1 Flusmount's wired into AUX4
And a couple of Diode Dynamics Stage Series Rock Lights under the hood.
I was thinking about throwing some S2 flush mounts in the same location, is there a reason you went with S1s?
mtesni
CT
24 Ranger Raptor, 23 Bronco Badlands
I wanted to be able to fit a 35" Spare in the stock location and figured the smaller lights gave me some more room. As it was I had to rotate the passenger side one 90° to get it to clear the tire. Edited to add: The S1's are also priced like the S2 Sports but are listed with the similar lumen output as the S2 Pros.
Ford Ranger What did you do to your Ranger Raptor Today? PXL_20240609_205204581
(Drivers Side rotated for my own need for symmetry lol)
welker
Scottsdale, AZ
'24 Ranger Raptor
I didn't even consider that, I haven't checked the clearance again since I put my 35 under there. I will have to mock it up again and hopefully not learn a hard lesson about cutting before you are 100% something will fit lol
yoopercharged
How sketchy was it to mount the 2.5" collars without a wall mounted compressor?
Arsenall11
Maple Valley Wa
24 Ranger Raptor
Smoked the third brake light with matte peal light spray. The third is still bright.
Ford Ranger What did you do to your Ranger Raptor Today? IMG_0073
Arsenall11
Maple Valley Wa
24 Ranger Raptor
Not sure I posted this added the Builtrite molle to the bed, waiting on the rear drivers side piece to be released.
Ford Ranger What did you do to your Ranger Raptor Today? IMG_0059
