What did you do WITH your 6G Ranger today?
Ford Ranger What did you do WITH your 6G Ranger today? 1000019339
Ford Ranger What did you do WITH your 6G Ranger today? 1000019341
Got the Honda FourTrax Rubicon loaded up yesterday and then drove to the in-laws up on Michigan.
Once we got there I took my son down to the river on the FourTrax.
Ford Ranger What did you do WITH your 6G Ranger today? 1000019390
Next morning when I got up it was raining and everyone was still sleeping so went out for coffee and drive, got bore with the Shelter Green color and decided to change it to a new color i made called Wet Gravel Dust...
Ford Ranger What did you do WITH your 6G Ranger today? 1000019385
Ford Ranger What did you do WITH your 6G Ranger today? 1000019383
Next year ill get a utility trailor but for the few times this year the bed works with DG tailgate supports (2015 Silverado 1500 ones fit with a little brass shim stock).
got3fords
James
Central Va.
I used my Raptor as a gun rest. I used the back corner of the bed for a steady rest to dispatch a ground hog today. Some people complain the bed is too high. Not for this.
I ordered an off brand adjustable overland rack from amazon that had really good reviews. The maverick and frontier guys said it is super solid and the powder coating looked heavy duty
Cliff3
Cliff
Eugene, OR
26 F150 XLT 3.5EB, 15 Porsche Cayman GTS
Retired IT Consultant
I drove it home from the dealer. It's a tight fit in my garage, but I can walk in front of it and close the garage door, so it's good. Now to program the UGDO..
Ford Ranger What did you do WITH your 6G Ranger today? IMG_4865 copy
NM Mike
Tossed in a couple of rifles, a bench and some other gear and went shooting on some BLM land.
Took off the tonneau and put the lumber rack on
Ford Ranger What did you do WITH your 6G Ranger today? 20260524_175447
Ford Ranger What did you do WITH your 6G Ranger today? 20260524_175459
Carried 2x6x16s and corrugated metal for the carport. Maybr next year i will get the last little bot done, ha ha ha.
I got this pipe rack from harbor freight for my 04 ranger stepside because it was adjustable. And it also adjusts perfectly for the 24 ranger too. Its a few years old but its aluminum so no corrosion issues
Ford Ranger What did you do WITH your 6G Ranger today? 20260525_140021
Ford Ranger What did you do WITH your 6G Ranger today? 20260525_143208
Those racks come with clamps to hold them to the bed but that wont work on our beds because if the plastic top. Luckily i had ordered those bed tie downs and under bed lip nut straps from @American Adventure LAb because those tie down bolts were perfect to hold these rack bases down. I just drilled holes to match the tie down holes and i now have solid mounted pipe racks on the truck.
And she is back to a sport truck. No racks or anything. Man, i love this truck
Ford Ranger What did you do WITH your 6G Ranger today? 20260525_181726
jmt8706
2025 Ranger Lariat
I used my Ranger to pick up 8 jugs of Mobil 1 ESP 0W-30 while it's still available. The Iran war is resulting in a shortage of Group lll base stock.
Toyota is already running out of 0w-8 and 0W-16. The auto manufacturers are hording supplies and are anticipating running out of synthetic oil by mid June.
If you do your own oil changes I suggest you stock up ASAP.
Synthetic Motor Oil Shortage Could Be The Latest Supply Chain Constraint
The 2026 motor oil squeeze
Thanks for the heads up. 👍
