What gear am I in?
DanTheMan
Dan
Escape
Social Worker
I am driving an XLT FX4 high equipment with the tow package. Is it not possible to display which gear the truck is in? I feel like that is a basic feature for a truck with 10 gears.
452Ranger
Illinois
2024 Lariat, 2017 Miata GT RF, Volvo V90
On my Lariat 4X2 there is a button on the drivers side of the shift lever. If you push that button it displays all 10 transmission speeds with an indicator as to which gear is in use. Not sure if this is the same with an XLT 4X4. Hope this helps.
DanTheMan
Dan
Escape
Social Worker
I have the gear shift buttons, I'll give that a try. Thanks.
willy
jeff
FL USA
2024 Ranger
on my Lariat, after shifting into D, press the + button on the left side if the shift knob and it displays.
Crapblaster
I made the forscan change on my F150 to show it all the time. It should work on the rangers also
Dubfound
Earth
BMW
My RR will show it in sport mode in the enter of the tach
Moto26
Scott
Tucson AZ
'21 Bronco, '17 F150
Ford did this on the Bronco as well. :headbang: If you're in D and want to see the gear you're in, you have to use the +/- button (as if you're in Manual mode), and a tiny number will appear - but only for a couple of seconds! Why they can't just leave it on there full time, I'll never know...
markal49
Mark
2024 Ranger XLT w/ FX4
Planner
This works on my XLT FX4.
jedadiah
Jed
Kentucky
'24 Ranger XLT 4x2
Press the + button on the shifter when you are in drive. You have to do it each time you start the truck.
DanTheMan
Dan
Escape
Social Worker
It totally works. Thanks everyone.
HyperM3
Alex
Lawrenceville, NJ
Does it continue to show the entire time youre driving the truck? Or does it shut off after like 5 seconds?
superakcraig
Allen
Louisville, Ky
2024 Ford Ranger Lariat
It will show until you shut off the truck or hit the button again.
HyperM3
Alex
Lawrenceville, NJ
