What is this for?
Geo8866
2025 Ranger Lariat FX4
I am getting ready to install a Bakfip cover, which comes with drainage tubes. ( My last two did.) Can I assume the black plug at the front of the bed that I have circled in the photo can be cut and used for drainage? Is that what it is actually for or does it have another function? Thanks
Ford Ranger What is this for? tempImageiHPDNy
AugPal
Augie
Chicago
Retired IBEW
Don't you have drain tubes towards the front of the bed for drainage already?
Geo8866
Geo8866
I see no drain tubes in the bed. The cover has drain tubes to funnel water out of the bed rails.
AugPal
Augie
Chicago
Retired IBEW
My truck had factory drain tubes that the covers drain tubes fit into. I'll go take a picture.
They were not factory drain tubes, rather drain holes. I have these drain holes on both sides and the cover has a drain tube on both sides.
Don't know if that helps you.
Ford Ranger What is this for? drainhol
fordgt
I used the area under the rail rather than drilling through those plugs. Drilling through the plugs is the recommended in the instructions. I didn’t want to drill them because they were covered with factory bed liner. Been like this 2 years with no issues.
Ford Ranger What is this for? imag
Geo8866
Geo8866
That's perfect. I didn't even notice those holes until your post. That is what I am going to do. Thanks!
AugPal
Augie
Chicago
Retired IBEW
fordgt
I have a FORD Rev cover which is a 4 panel cover. But I think it’s similar to one of the BakFlip
fordtrks4ever
Perkiomenville, Pa
I also used holes already in the bed
I did not like running the tubes down because a could just see loading something in the bed that
would mess up the tubing.
Bruce
Bruce
Minnesota
Your idea to use the holes in the bed sides is good to a point.
The pictures show that you do not have a direct drop for drainage, so water will sit in the plastic hoses.
If the instructions say use the plugs, to it, gravity is your friend when draining water.
Gray Ranger
James
North Dakota
2025 Ford ranger lariat
On my 2025 I have drain holes in the front of the cab, same size holes as you have.
fordgt
2 years - jit’s never once been an issue.​
