Wheels
hot4rd
ohio
Ranger Raptor C 8 Corvette
I am trying to find wheels for my 2025 Raptor not having any luck. Is there a company that makes wheels with the factory offsets or close to them? I want to stay with the factory size wheels and tires. Right now I have the beadlock wheels. Thanks..
pohnz1
Christian
Pa
25 Ranger Raptor
The closest you're going to find is +35. However, +25 puts a wheel damn near flush with fender
Daweism
Austin, TX
RTR makes wheels specifically designed for the Ranger that is hub centric and super lightweight. I went with the EVO 6 17x9 with 30mm offset. These are 22.5lbs vs stock at 28.5lbs vs stock beadlock at over 37lbs. This weight savings at the wheel is probably one of the biggest upgrades you can do for your truck at the bang for the buck. It is hard to find hub centric wheels for the Ranger.
Every pound saved at the wheel (unsprung weight) is equivalent to 10 lbs on the truck (sprung weight). It improves mpg, acceleration and stopping.
https://www.rtrvehicles.com/collections/ranger-rtr-parts-2024
Deleted member 9086
Tire Rack has nothing but Discount Tire has several different makes and models.??
Fattirz in NC
Charlotte, NC
Designer/Draftsman
Check out Method Race Wheels. For awhile I believe they had a partnership with Ford Performance or at least dealers. I’m pretty sure Discount Tire carries them too. They make a bunch of wheels that will work with the Ranger. They have a few I’m interested in too, if I end up the pulling the trigger on a new Ranger?
https://www.methodracewheels.com/collections/all
pohnz1
Christian
Pa
25 Ranger Raptor
Tire rack you have to think outside the box. You need to search under a ranger 4x4. Plenty of 17x8.5 choices
Johnny 5
John C
Mold maker
I bought these Raceline wheels for my Ranger Raptor. They are +35 offset. I called up my local BelleTire store and asked them if they could get me a set of these and they could. So I had it all done right through the local wheel store. Some wheels, they have these offsets, some of them they don't. Look their whole site over and over.
Ford Ranger Wheels 20241106_100033
Ford Ranger Wheels 20241106_100047
Ford Ranger Wheels 20241106_100059
Ford Ranger Wheels 20250313_073640
Johnny 5
John C
Mold maker
Is -25 a typo? Those look like +25 offset.
You are somewhat correct. They are actually a +35 offset. Man am I glad they aren't a - offset !
WESTRESCUE77
J
Westchester, NY
I believe Nomad, Evo Corse, and Braid have options that will fit the RR. Can't seem to find any pics though...
I think it is prudent to buy OEM wheels, with a correct hub centric fit, for when you trash one and have to find an exact replacement. You will easily be able to find a newly remanufactured Ford wheel many years from now. I bought a set of FIVE Bronco Outer Banks 17" wheels including TPMS and center caps, for just $650, on my local Craigslist. They were perfect takeoffs with just 100 miles use. I use my butt ugly, grossly overweight "beadlocks" (with rings removed!) for my winter tires, and the narrower Out Banks wheels with my stock TKO3's for summer. The narrower width protects the rims better. See any wheel here that you like?
https://www.ford.com/suvs/bronco/models/
scrappyisbe
james
iowa
24 RR
I
Just got a set of those wheels for mine, what tire size are on them? I'm going to do 35/12.5r 17
Johnny 5
John C
Mold maker
I
Those are the OEM (stock) tires. Post some pics when you get them.
