When do we change our transmission oil ,flush, and filter, 2.3 ecoboost 2019-2024
Ranger #1
Scott
New Mexico
Ranger
Hello 👋 friends, just wondering how many miles should you change your tranmission oil ,flush and filter on a ford ranger 2.3L from 2019-2024, just needing to know for future reference lol mine is still in the break in process, I've been told by Seaford dealers from 30k to 100k ,I want this tranmission to last 250k or more, it's the 10R60 transmission! Thanks
Ranger #1
Scott
New Mexico
Ranger
Several Ford * sorry for the misspelling
ShadeTree
Barry
Republic of Texas
2024 Ranger Raptor, 2016 Wrangler Rubicon, 1947 Willys CJ2A
engineer
According to Ford, the 10R60 in my RR is recommended for a transmission fluid change at 150K miles.
Ag3ntC00p3r
Wisconsin
Product Manager
Not taking into account what service interval people should or will actually follow, you can view your Maintenance Schedule from your Vehicle Dashboard on Ford.com.
https://www.ford.com/support/maintenance-schedule/xxxx/
xxxx=your VIN
This is what RR shows so 2.3/2.7 may be different
A mix of the following up to 100K
  • Replace engine air filter(s).
  • Replace cabin air filter, if equipped.
  • Inspect brake pads, shoes, rotors, drums, brake linings, hoses and parking brake.
  • Inspect engine cooling system level, strength and hoses.
  • Inspect exhaust system and heat shields.
  • Inspect front axle and U-joints. Lubricate if equipped with grease fittings.
  • Inspect half-shaft boots.
  • Inspect steering linkage, ball joints, suspension, tie-rod ends, drive shaft and U-joints. Lubricate if equipped with grease fittings.
  • Inspect the automatic transmission fluid level (if equipped with a dipstick). Consult your dealer for requirements.
  • Inspect the wheels and related components for abnormal noise, wear, looseness or drag.
  • Perform multi-point inspection.
  • Rotate the tires, inspect tire wear and measure tread depth.
At 100K
  • Replace spark plugs.(6cyl)
  • Inspect accessory drive belt(s).
At 150K
  • Change automatic transmission fluid and filter.
  • Change front axle fluid.
  • Change rear axle fluid.
  • Change transfer case fluid, if equipped.
  • Replace accessory drive belt(s) if not replaced within the last 100000 miles (160000 km).
Ranger #1
Scott
New Mexico
Ranger
xxxx=your VIN
At 100K
At 150K
Thanks guys for your reply
beaudointl
Tim
Ontario, Canada
Technician
As a retired Ford tech and with a similar desire to keep transmissions going for a long time, 50k should not be exceed in a modern transmission. Being solenoid shift with mini filter screens and very close tolerances in the valve body you don't want to wait too long. The first change at 30k, once the break-in particulate is complete isn't unreasonable. Then do the fluid and filter at around 100k.
Ranger #1
Scott
New Mexico
Ranger
Thanks for the reply, ok so 30k to start of then 50k after, i mean 50k each time after,I'm not going to horse whip or pull trailers, I'm driving with a lite foot on the gas! My pickup only has 1050 miles so far
Ranger #1
Scott
New Mexico
Ranger
I think I'm going to flush, replace filter, at 30k, then at 80k then 130k etc:
beaudointl
Tim
Ontario, Canada
Technician
That is the best way to ensure smooth operation for years to come. Changing the filter every 50k maybe overkill but every 100k is sufficient. A lot depends obviously on how you use it but those frequencies are good for the average owner. Personally, eventually I would but a tranny pan with a drain plug to make the job so much easier. That way you don't have to drop the pan for your fluid changes. I should have added that at that first 30k change, do the filter to ensure all break-in debris has been removed.
beaudointl
Tim
Ontario, Canada
Technician
Service intervals are written by Ford corporate withe main idea isn't longevity, they just need to get it out of the warranty period. Their goal is to show the EPA and government climate watchdogs how little waste there is and low cost of maintenance. Even dealerships will knowingly deviate from these intervals knowing it is not the best for their customers. Whenever in doubt, follow the severe duty intervals regardless how you drive , that is what's best for your vehicle.
Ranger #1
Scott
New Mexico
Ranger
Thanks for the reply back ,yeah I'm just going to do what I said earlier 30k fresh oil flush filter and at 80k etc it only cost about 400 at this ONE HONEST Ford dealership and that's everything, ok this is a 10R60 tranmission, which is the better tranny what aluminum pans will fit this tranmission ,I cant find one that specifically says 10R60 will the 10R80 pans fit ,if not what pan will fit this tranny, I've got the 2024 ranger 2.3 ecoboost, thanks!!
dard6555
https://us.bddiesel.com/products/de...-ford-10r60-10r80-2017?variant=42877598302391
beaudointl
Tim
Ontario, Canada
Technician
Ya, the 10R80 and 10r60 are almost identical. So a 10R80 pan should fit a 24 Ranger 10R60. However, I haven't bought one yet so please question your seller and do some research just to be sure. Internally they use that same overhaul procedure and the pans were the same. However that doesn't mean Ford could have done something goofy. Research to be sure.
Ranger #1
Scott
New Mexico
Ranger
👍 yeah I know thanks
isslandboy
Greg
Se Alberta
2025 Lariat, 2014 Toyota Fortuner
Great info. Miles or KM for the recommendations?
