Where to locate drain holes?
FossIsleBC
Victoria, BC
2024 Ford Ranger XL
Just got my tonneau which has drain tubes (they sent me the wrong cover. It’s more expensive than the one I ordered and it flips so I’m gonna keep it, but the one I ordered sat above the rail and didn’t need drain tubes. This one sits flush and requires them).
There are no pre-existing holes in our beds to route these tubes through. Where did you guys put them, and how did you seal the cut metal? I really didn’t want to drill into factory sealed metal.
There are 2 plastic cover at the front of the bed. That is what they are for just have to drill a hole through them.
FossIsleBC
Victoria, BC
2024 Ford Ranger XL
That worked. They sprayed the factory liner over those so didn’t realize they were hard plastic I could drill through - thought they were rubber.
Thanks again CactusGreyFX4 - appreciate it ?
Rda2w
Robert
Upstate NY
A little hard to see in this pic. I ran the drain tube into already existing holes near the top of the side wall.
Ford Ranger Where to locate drain holes? 1721394120896-xr
patc890
Patrick
Rockville, MD
Good idea. I didn't even notice those holes. A bit neater and less chance of getting caught in something. I put my drain out the bottom holes.
Ford Ranger Where to locate drain holes? IMG_0272
DanTheMan
Dan
Escape
Social Worker
I also ran mine there. I had hopef that was an acceptable spot. I couldn't see where it led to from under the truck because of the wheel well cover.
fordtrks4ever
Perkiomenville, Pa
I did the same but used a 90-degree plastic elbow so the hose would not kink.
RaptorWaiting
Mark
Maryland
High Tech
This is where I ran mine
