Wildtrak Headlight Upgrade - Performance Led
wenman92
Tom
England
2024 Ranger Wildtrak
Hello
I’m looking for some advice regarding my 2024 Ranger Wildtrak (UK). I’ve upgraded the headlights from the Level 2 (LED reflector) to the Level 3 Performance LED units, which are genuine Ford parts.
At the moment, the low beams and DRLs are working fine, and the indicators also work — although they flash rapidly inside the cab as if a bulb is out. However, I don’t have high beams.
After checking the plugs and comparing the pin layouts, I noticed there are some differences. Has anyone here done this upgrade before? Is there a quick fix, pin reconfiguration, or FORScan change that will make them work properly?
Any advice would be greatly appreciated.
Regards
Tom
Ford Ranger Wildtrak Headlight Upgrade - Performance Led eecd9acc-ba6c-4fa1-aab6-cd83b63bc567
Ford Ranger Wildtrak Headlight Upgrade - Performance Led A5975D3E-7EC8-40FE-825D-20D28A1D84A0
there is stuff in forscan that talks about the types of lights you have so you can make changes. but not sure what those changes do
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Yeah you’ll for sure need to make changes in forscan. Not sure what changes they are, but there’s a whole bunch of lighting settings in there
ShadowDragon24
2025 Ranger XLT Fx4
Heavy Equipment Operator
Forscan. turn off bulb out indicator. there is led option. but in my led reflector headlights, i put in led bulbs. and when I turned off bulb outtage, and turned on led bulb outtage, I still got hyper flash. turned off bulb outage and led outage. and no hyper flash(bulb out)
Maty
Czech
Ranger 3.0V6 MS-RT
Hi,
I would also like to upgrade the LED lights on my Ranger MS-RT, the standard LED lights are terrible. I was browsing the individual units in Forscan and found the Headlamp Style item in the BdyCM unit where you can select 4 types of lights.
Does anyone with Performance LED lights have the ability to look in the BdyCM unit settings to see what type of lights they have set?
Ford Ranger Wildtrak Headlight Upgrade - Performance Led PXL_20251021_155815517
