2.7 oil dipstick with “H” stamp
BriSco
'24 Ranger XLT, 2.7L V6
Can anyone confirm the dipstick with the Triangle stamp exists? Or are they all stamped with the H designation?
I’m referring to a 2024 Ranger Lariat with the 2.7 EB engine. The EPN on mine is FT4E-6750-BG. My understanding is that the new triangle stamp is the newer version. If anyone can confirm this I would appreciate it. Thanks to all replies and thanks to the forum.
OK, I posted earlier that my '24 2.7 has an H and measured at the full mark at ~4200 miles.
Also my p/n is the same stamped into the blade of the dipstick. Also I measured from the bottom of the flange on the handle to the full hole and I get exactly 18 3/4" for reference.
I changed the oil and filter adding 6 quarts of Kirkland 5w30 synthetic and a Motorcraft filter.
Started it, checked for leaks. Shut it off and went backabout 15 minutes later. The dipstick was at the full hole.
Also changed to the Dorman drain pug with downward facing hole at the same time. Amazon link.
Youtube video
This *should* make oil changes much less messy.
rlcampbell64
Randall
Cross Plains, TX
2024 Ranger Lariat Sport 4x4
Youtube video
Thank you for the replies. Have you tried checking it after sitting overnight?
Mine always reads the highest on a completely cold engine. It appears the 15 minute interval described in the manual is the only thing that makes sense. I know mine appears much more overfilled any time after that. Even by 20 or 30 minutes. Thanks again for checking it out and replying. I appreciate it 👍
tt-rangerV6
Tim
Holley, NY 14470
2025 Ranger V6TT
Food category Manager
Anyone else have this issue, or can chime in?
Thanks for any assistance and thanks for the great forum.
Crazy, this is driving me crazy. I changed first at 1000 miles (break in) added 6 quarts of Mobil 1 Synth. After a few weeks now I checked it, just to see. Well, it showed low on the stick so I added 3/4 of a quart, well then it went way over!! So then drain a quart back out and take it off the ramps. waited 15 minutes, not even showing on the stick!! LMAO. what the hell is going on. I have the H stick too so, I will be calling dealer to see what I am supposed to do.
rlcampbell64
Randall
Cross Plains, TX
My dealer told me anywhere on the dipstick is fine….well that was no help. I told him I’m aware of the check valve and I’m trying to confirm correct dipstick after the Bronco issue. He had no idea what I was talking about. I have had a 2.7 before (2016 F150) and although that check valve can fool you depending on when you check it, the 2016 had a different dipstick and I was able to get more consistent checks.
Thank you for replying to this thread and I would be interested in hearing what your dealer tells you. Please let me know, good luck!
Reddog99
So. Cal.
2024 XLT Ranger FX4 2.7
After reading this thread, I checked my oil level and saw that it appears to be overfilled by one quart. The oil was last changed by the dealer. I need to take the truck in for the recall soon, so I'm going to ask them WTF is going on.
rlcampbell64
Randall
Cross Plains, TX
Likely not overfilled, I have measured mine ….6 quarts out, 6 quarts in…still appears overfilled. It all depends on when you check it. I believe it is the check valve for auto start/stop. 2.7l
Marken
Ken
Alberta
2024 Ford Ranger Lariat, 2018 Ram 3500 Longhorn Dually
Has anyone found the issue of why lipstick shows overfull after sitting?
When I check my oil level after 15 minutes it shows just over full. When it has sat for a couple days it shows way overfull. Should I be draining any off?
rlcampbell64
Randall
Cross Plains, TX
That’s been my experience as well, six quarts in, six quarts out. The dipstick always reads that way. I believe it is the effect of the check valve ( auto start/stop)
alrashid2
PA
Anyone know what the H means?
Just another great byproduct of the wonderfully useful Auto Start Stop Feature, sheesh.
I’m not so quick to “blame” auto start stop. I say this because I have a Mercedes with no auto start stop and the first time I pull the dipstick it’s bone dry, regardless of whether the engine is hot or cold. Put the dipstick back in and the reading is accurate. So maybe in our ford’s it is because of auto start stop, or maybe not.
LeeHo
Lee
Niles, Mi.
Here is the answer from "Bronco Nation". It is the same issue, same engine different vehicle. I tend to believe this is the answer. I have a 2024 2.7L Lariat and plain Dipstick and do not have any issue with a 6 Qt fill.
The Reason for the "H" Stamp Difference
  • The Dipstick with the "H": This is the older factory design (often found on earlier iterations of the 2.7L EcoBoost or standard factory builds). The "H" on the yellow plastic handle piece acts as a design label. This older version often caused false high-reading indications where owners noticed the oil sat well above the top mark, even with the factory-specified amount of oil poured in. [1]
  • The Dipstick without the "H": This is Ford's updated, superseded replacement part. Ford redesigned the plastic moldings and measurements slightly for this part. The newer versions usually remove the "H" handle text and instead replace it with a small triangle or blank space. This updated version corrects the tracking depth, reading roughly 3/4 full with the exact factory oil capacity. [1]
alrashid2
PA
That is interesting, but I wonder if that data is inaccurate. Just got my ordered Ranger 2.7L and it has the H still. I doubt they have old stock dipsticks years later... 🤔
