UNSHLTRD
Rich
Las Vegas, NV
It looks like BuiltRight Industries just dropped their new Molle panels. I do wish they had gone with a bulkhead Molle panel instead of their current accessory rail system.
The price is definitely appealing—cheaper than the ADD panels. I’m holding off for now because I want to see what American Adventure Lab comes out with. If their panels look good, I might go that route instead before committing to the BuiltRight ones.
macky
Central PA
'24 Ranger Raptor Shelter Green
I’m ready to preorder. Just want to look at the specs if I can to see if it will work with the rails for the Lomax trifold cover.
Reactions: Doc
mtesni
CT
24 Ranger Raptor, 23 Bronco Badlands
Glad to see these dropped today! My truck was used for some development and the pictures/videos!
I have a Retrax cover and worst case will have to trim a little bit of the top of panels for the mounts. We were glad that everything was able to be easily fit over my Ausmotion compressor bracket.
Sauce
Northeast
2025 Ranger XLT FX4
Somewhat off topic, but since you mentioned the Ausmotion and have the air chuck - why did you decide to mount the compressor on the passenger side and the chuck on the drivers side rather than having the chuck on the same side of the mount? DId you mount a single or double? Where did you mount the switch? Im considering the Ausmotion setup myself and probably leaning towards the brushless single.
The molle panels look really clean and I'm considering these too.
mtesni
CT
The Ausmotion bracket only works on the passenger side. I opted for the air chuck on the drivers side to keep it clean in the accessory panel rather than an additional hole in the bed. I'm also in the process of adding the ARB air tank using the Pirate Camp Co bracket on the drivers side. I have the brushed twin compressor, the brushless twin is a different mounting pattern. I have mine wired to AUX3 for switching and extended the power leads up to the battery
This will give. You an idea of the look.
did you move your jack to that point, or is it a raptor thing thats different from the regular ranger?
jrlrule
J
TX
This seems to be made out of aluminum which is great to keep cost down. Compared to ADD and adventure lab's steel (from the looks of it). Unless adventure lab has an introductory pricing, price wise this is a great option.
adrouin64
Austin
Jay, ME
Marketing Manager
I could be wrong but I’m pretty sure @AdventureLab panels were aluminum in the photos I saw.
jrlrule
J
TX
AH ok I can't tell the difference, plus it's mentioned on the post that its made of aluminum lol
Reactions: Doc
