2025 Order update
Grabber
NJ
2024 Ranger Raptor, 2020 Super Duty Tremor & 2009 GT500
Those of you that have your blend date of 3/31 and can view your window sticker, check for the numbers to the left of the QR code at the top of the window sticker. That is suppose to tell you how many rangers they are building that day and your order on the assembly line. Just curious, mine is number 630 of 1641 being built.
Daweism
Austin, TX
Ford Ranger 2025 Order update 1742940916094-66
SolarWinds
PNW
IT Director
It's so painful being within the one-week delivery window and refreshing the order tracking every hour
Grabber
NJ
So that must be correct since the second four numbers are the same.
pohnz1
Christian
Pa
25 Ranger Raptor
Alright. My order finally went back to order confirmed. Shipping soon
Yonder_MN
Joe
Minnesota
Finally updated to production! 1100/2565, Blend date 250403 (Thursday!)
- Joe
Moonlit
Pittsburgh PA
2025 Ranger Lariat (Marsh Gray, Rear Locker and BAP)
Mine updated too - Blend of 0403 with numbers of 1662/2565. Interesting that they blend the same day but are so far apart number wise.
Do they really build that many a day??
Grabber
NJ
It's a week, I was wrong.
Awirez
Makes sense. ~15 vehicles an hour off the assembly line... assuming 24/7 operation. I heard the max capacity is almost double that.
My order is a 4/2 blend! 😁
SEV3N8T1
Michael
2025 Ranger Lariat - 2.7L
1467/1641
Moonlit
Pittsburgh PA
Grabber
NJ
Might include Broncos also since they go down the same assembly line.
Awirez
These numbers have changed for me. The numbers are much smaller, 307/485. I presume because my truck is routed to go to Ground Effects (does the Line-X spray-in bedliner and any other non-assembly line things prior to shipping).
The 4-digit large number to the immediate right of the blend date has remained unchanged.
I would deduce that the 4-digit number to the right of the blend date is the blend number for the actual MAP production. 🤷‍♂️
Awirez
Also, if anyone is eager to have a better understanding, there is a link that gives decent information about where your trucks offload rail yard would be. It may be slightly dated ("RAMP ONE" didn't exactly match what is on my sticker currently, maybe it will change prior to getting done in production in the coming weeks) but I'm able to figure out where my truck would be offloaded from a rail yard.
RAMP CODES for New Truck Deliveries - Ford Truck Enthusiasts Forums
2019 AAR Terminal Guide Master 1.1.19.pdf
