2025 RR / Newbie Q. No lights on door open an option?
Aircraft examiner
I had it enabled via Forscan so it's an option in the center menu. I can turn it on when camping, and off if we're staying at a hotel for the night. I better check to make sure it's still there before my trip in June.
Wherr in the menu is it? I have it also and cannot find a place to enable or disable on the menu
I have quiet mode enabled , not dark mode, because its to but if could find a switch ro acrivate/deavtovate, that would be different.
OxygenMask
Phil
Eugene, Oregon
Why is the dome lights coming on when camping such a problem?
I just today returned from a 5 day camping trip. Been camping with my own vehicle since 1977... Never once thought the interior lights coming on when I opened a door was a "problem"....
pablo94sc
Focus
It's the exterior lights.
Silent Mode (aka: dark or police mode):
Ford Ranger 2025 RR / Newbie Q.  No lights on door open an option? 20260422_225132
Aircraft examiner
mine for sure doesn't have the option on the center screen. i will try again this afternoon to activate it and look for that because if it ends up i do find that, i will leave dark mode on than
Reactions: TSY
pablo94sc
Focus
It's in Forscan. Can't remember if it's one or two fields you need to change, but once you change it, it'll be in the menu.
RCMUSTANG
Ray
Los Angeles
1989 Mustang 2017 Fusion
It needs to be done in the bcm and IPC of i remember correctly.
Aircraft examiner
i will look at the spreadsheet when i get home and finish cutting hte grass after work. i cannot open it at work because its blocked on our system
