3.0L EB to be new base engine in '27 F-150
Mystic
Rusty
SoCal
'24 RR, '25 Explorer ST
Estimator
https://fordauthority.com/2026/07/2...2-7l-v6-ecoboost-for-3-0l-as-standard-engine/
Not really a "Ranger vs competition" topic, but didn't know where else to put it.
I think this is interesting for a number of reasons. Clearly Ford thinks the 3.0L is proven enough to put in their best-seller, which isn't really surprising given it's basically a bored & stroked 2.7L underneath. The 2.7L (and now by extension, the 3.0L?) is widely known to be highly reliable.
Makes me wonder where this leaves the 3.5L EB, as there's not a ton of delta (power, fuel economy) between the two. And Ford is now putting the 5.0L back in the higher trims.
I have a sneaking suspicion there will probably more powertrain shuffling to come..
yoopercharged
Interesting. Wonder if they’re just trying to phase out the 2.7L and streamline powertrain offerings. I’ll be curious to see if it’ll be detuned at all.
HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
Hopefully they make it direct and port injected if this comes to pass.
I would expect that's what they do. Ford seems to be going dual injection with all the motors.
The 2.7 has been Ford's bread and butter for the last few years. This is definitely an interesting turn of events. If the F-150 is losing the 2.7 I wonder if this will be the death of that powerplant across the model lineup. Which leads to other questions about the Ranger and Bronco. The new 2027 Bronco Filson edition has the 3.0...
jmt8706
2025 Ranger Lariat
Makes me think they might remove the 2.7 from the ranger, and just keep the 2.3 and 3.0 for the RR.
Texasota
Al
Rochester, MN
Yes, it sounds like it is going away. According to a reliable source on Blue Oval Forums it has to do with emissions regulations for the 2.7.
Bigsack
Mid-Atlantic
26' Ranger Lariat
Lovely, what's that mean for parts and repairs in the future?
Jasonkflo
Boise Idaho
25 ranger
sales
So does that mean the 2.7 Ranger in general will be rare?
HighDesertRanger
Oklahoma
Ford Fusion 2.7
Sales Manager
It doesn’t really make sense that emissions on the 3.0 would be any better than the 2.7. They’re both based on the same motor.
pezdyspensr
New England
2024 Ranger STX
This may ultimately be about cost control. From what I understand, Ford is making moves to unify engine production. Isn’t the concept behind the MPC that all future engines share internal components - hence the term modular?
The 2.7 has different cylinder dimensions from the 3.0 according to a quick search.
Switzguy
Minnesota
2025 Ranger Raptor, 2018 BMW M240i
Ford is scrapping the 2.7L in the F-150 for cost-saving, manufacturing efficiency, and line-simplification reasons, rather than because of any mechanical issues with the 2.7L engine itself. [1, 2, 3]
In fact, industry insiders and automotive analysts attribute this 2027 order guide shake-up to two major financial and logistical drivers behind the scenes: [1]
1. Supplier Agreements and Manufacturing Timelines
The next complete, ground-up redesign of the F-150 was heavily rumored to debut for 2027 but got delayed. “The rumor is the full redesign of the Ford F-150 had been delayed a year due to the impact of tariffs and aluminum supplier issues...” as reported by Pickup Truck Talk. [1, 2]
However, Ford had already signed strict long-term manufacturing agreements with part suppliers to ramp up 3.0L production at the Lima Engine Plant. Because those suppliers could not pause production for a year without massive financial penalties to Ford, the automaker chose to phase the 3.0L engine into the current truck platform early to honor those contracts. [1, 2, 3]
2. Assembly Line Simplification
Building two slightly different versions of the exact same "Nano" engine family (the 2.7L and the 3.0L) on separate tooling setups is expensive. By phasing out the 2.7L from its highest-volume vehicle—the F-150—Ford can drastically streamline its supply chain. Running the majority of its mid-tier V6 production tooling for a single, uniform engine size reduces tooling changeover costs and maximizes economies of scale. [1, 2, 3]
3. The Power Loss Counter-Measure
Ford recently began installing Gas Particulate Filters (GPFs) to satisfy tightening global emissions mandates. Adding these filters to the exhaust causes a restrictive drop in performance—for example, the 3.5L EcoBoost saw a notable power drop when its GPF was added. [1, 2]
By increasing the base engine displacement to 3.0L, Ford can absorb that emissions-related power loss. The larger displacement ensures the 2027 F-150 can meet strict environmental standards while still offering a power bump over the old 325-hp base model. [1, 2, 3]
ryanO
Ryan
2025 RangerXLT
Sales
This makes a lot of sense. From a business perspective, the more streamlined and simpler you can make production, the more you can control profit margin.
purdyd
california
to me this is what is wrong with AI
non of those references support the text and it includes some forum chatter.
there is nothing above that supports the reasoning why ford made the change.
I’m not saying it is wrong just the references don’t support the conclusions.
and of you are going to quote ChatGPT, I think you should note as such and include the query.
Switzguy
Minnesota
Fair enough since I didn't post the full context as it would have been a wall of text. You can prompt Google Gemini with more and more information and it will spit out more accurate information. And it does have access to these forum posts.
Texasota
Al
Rochester, MN
In the new F-100 (which will replace the Ranger in North America) you may see a detuned 3.0 replace the 2.7 and the higher output 3.0 in the Ranger/Bronco Raptors. Fits with plans to consolidate engine lines resulting in better economies of scale. Or we might see a higher output 2.3 replace the 2.7.
