35's can rub upper fender flare
Klutch
Cole
Saskatchewan
Just an fyi. No rubbing during wheeling. But when jumping and at full compression, the tire must balloon a bit and contact the upper part of flare. Watch the front tire in pic/ video.
Ford Ranger 35's can rub upper fender flare Screenshot_20250623_064012_Video Player
Klutch
Cole
Saskatchewan
Garaged
Usa
Ranger raptor 2024
So even with strut spacers for lifts (how many inches are yours?), if you put 35s on stock wheels, they'll still rub at full articulation?
I wish someone would find the right recipe for the best non-portal lift lol.
Klutch
Cole
Saskatchewan
my spacers are to get a 2 inch lift. I don't have rubbing at full articulation, only when landing. Tires are also at 28psi. I didn't want to mention my wheel spacers from rokblokz but they also factor in. I didn't want to hear about the whole wheel spacer good or bad business. I'm fully aware of the down sides.
Garaged
Usa
Ranger raptor 2024
Got it. No, selfishly, I'm trying to figure out my plan for possible 35s when my 33s start wearing out someday in the future. I currently have the stock KO3s on the stock beadlock capable wheels with no lift and with the BORA 1.5" spacers (not strut spacers, I mean wheel spacers).
I have only jumped it a couple times pre-spacers and a couple times after and I didn't notice any damage.
Klutch
Cole
Saskatchewan
Roger that. I'm pretty satisfied with my current setup. No plans to change any time soon. I think id only change if i get different tires in the same size next time that possibly cause rubbing. Currently on goodyeary territory
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
Its pretty simple. You need a strut spacer thickness that is equal to or greater than the tire radius increase. The other factor to consider is that the wider the offset wheel the more clearance you need. The ideal offset being+35 or +40 to keep the contact patch as far inside as possible.
Garaged
Usa
Ranger raptor 2024
Thank you. Ok, so I'd need 2" strut spacers for a 35" tire on stock wheels. But then, would my BORA wheel spacers (1.5") actually make things worse not better with that setup given what you said about the contact patch?
Klutch
Cole
Saskatchewan
Thinking about this, I only installed a spacer to get an inch of lift. I believe i used a spacer from rough country for a bronco because i didn't want to clock the top hat. A 2 inch lift spacer should be enough for 35's then.
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
All I can advise RE strut spacers is based on the G.O.A.T Offroad ones I design and make, being they are 32mm thick to achieve 2in lift. Theres lots of generic spacers on the market, so I cant comment on their specific thickness.
Yes, your wheel spacers are giving you an effective wheel offset of P17 which is a pretty wide offset and does move your contact patch inline with the flares.
As above, our Raptor specific 2in lift spacer is 32mm thick, which is greater than then 25mm radius increase from the jump to 35s.
Garaged
Usa
Ranger raptor 2024
Thanks. Your spacers were definitely the ones I was looking at :) as well as the very helpful FAQ you had.
Yes, 17 was my math too (55 stock minus 38). I guess then I have to choose between the tire surface being flush with the fenders vs having a lift and larger tires.
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
Haha flush must have a very different meaning in the US :crackup:
We have a Ranger Raptor in the workshop on 17x9 +35 with a 315/70r17 and it failed inspection because the side wall is 8mm outside flares, when viewed from above.
Stephen
Aberdeenshire, United Kingdom
Raptor V6
Then a +40 17/9 with 315/70/17 should be just right. Eibach 40mm lift kit
nedmo
Gold Sponsor
Ned
Australia
2022 Ranger Raptor
Yep bang on.
BUT, have you read our article about lifting the Raptor? goatoffroad.com.au/rangerraptorlifts ?
Because the issue with spring lifts is they dont factor in clearance for large tires at full compression.
