Hofstetm
Hofstetm
Mitch
Update: I have removed the balance beads after 1000 miles - just not a fan. Over 55mph caused steering wheel wobble, and towing our single axel RV was even worse. After removal and normal [black, ofc] wheel weights were added, the truck is now flawless, zero wobble even over 75+ mph with the 35s.
FullSend
Ninjaneer
You can remove the rear crash bar also without cutting.
REAR CRASH BARS: If you remove these two bolts on the body panel, you can pull out on the panel just enough to squeak out the rear crash bar. Aim the rear crash bar towards the front as you pull on the body panel.
Ford Ranger 35s on Method MR305 NV wheels on Ranger Raptor :) REAR CRASH BAR.JPG
Hofstetm
Hofstetm
Mitch
Good to know!!
chrisriner
Holly Springs, GA
Mobile App Developer
How much more ground clearance did you get? Also did you reprogram for new tires size to make speedometer and gas mpg and cameras etc all work correctly with larger tire?
Hofstetm
Hofstetm
Mitch
Ground clearance increase was considerable. I did not measure but it was a few inches or more and for my extremely short wife - well, she's just happy I decided to keep the running boards.
I did not correct anything - yet (other than headlights). This is next on the list of things to do, though. Right now, I am GPS verified 2-3 MPH up from what's being displayed in the truck, so I remember that when driving. I went off roading this past weekend (cameras are used to show rocks/path in front/articulation/turning) and towed a trailer about 500+ miles before that (when towing the RR shows cameras for blind spot monitoring when the turn signals are used) and zero cameras were influenced negatively with the tires.
MPG right now, the truck says I am achieving 16.4 average - I have never reset this since I bought the truck. I already had the wheels and tires before I took delivery (and the truck was delivered to my house) and installed them immediately, so I have no idea what others are reporting stock. Again though, I also tow a bunch, off road, use remote start, have the Ford tune and enjoy the turbo noises - so I'm probably not the best judge of MPG. :)
Nikki_krause
Nikki
Hey all, I was able to mount these things today and they look absolutely incredible. Tire and wheel specs below.
Wheels: Method MR305 NV's, 17X8.5, +25 offset
Tires: 35x12.5R17 TOYO Open Country A/T III
Nothing rubbed until close to full lock. I did have to trim a bit on the front and rear bars which sit behind the wheels, but if you looked in the wheel wells you'd never notice. And no, I will not be lifting the front with a leveling kit. I'll be adding more weight to the rear soon, so I am not worried about a small bit of rake.
For those who are interested, YES, a full size MR305 NV + 35 ATIII does fit under the truck for a spare (in the stock location, without any trimming or hitting the exhaust.
Ride is about the same as stock, tbh. I don't notice any more road noise, too, surprisingly.
Last, I did use balance beads this go around, instead of wheel weights. I prefer not to gunk up the wheels and have fears they'll leave residue or fly off (the latter happened to me in the past).
Regardless, I can't be more happy with how it turned out. :D
Looks awesome! May I ask where you purchased the rims and tires. I can’t seem to find a matte black with matte black ring.
Hofstetm
Hofstetm
Mitch
Sure thing. Believe it or not, mine are the matte black wheel with gloss black ring. It’s not a high gloss though and matches my black truck perfect; between the semi-gloss paint and matte fenders. Plus, unless keep your wheels clean 100% of the time, the wheel almost always looks matte. ;)
Regardless, everything was bought on Tirerack.com. Don’t use the vehicle fitment finder, you’ll have to manually enter which size tires and wheels you’d like.
Pic of my very not clean wheel right now:
Ford Ranger 35s on Method MR305 NV wheels on Ranger Raptor :) IMG_7318
Nikki_krause
Nikki
Awesome thanks brotha, any chance you know the metric equivilant of a 35x12.5r17 or what does it say on your tire?
Hofstetm
Hofstetm
Mitch
315/70/17 is roughly the same, although, I think just the tiniest bit smaller than a true 35. Don't quote me of course, maybe someone can chime in who went that route!
Antman450
Anthony
Reno, NV
2024 Ford Ranger Lariat
What corrections did you do to the headlights? Did you just realign them, and if so, how do you do that?
Hofstetm
Hofstetm
Mitch
I didn’t do any headlight leveling. The RR does have auto leveling headlights (you can see them level when you turn on the truck at night) but I still do have a small front rake so regardless my headlights are never pointed to the moon, even when towing.
Rguest3
Raymond
FL and VA
F-series, BRaptor, Soon - RRaptor
Your truck looks great!
I'm surprised your tire/wheel combo fit so well with minimal rub.
How close is the inside of the tire to the Upper Control Arm? How much clearance?
Hofstetm
Hofstetm
Mitch
Thank you! Appreciate it. It fits great, and in fact, I believe it should have been this way from the factory. Fills out the wells much better, IMO.
In terms of how close the tire is, I've got a few inches. I've even aired down when off roading with zero clearance issues. Here's a horrible picture showing it, as I am too lazy to turn on my truck and turn the wheel for a better one. :)
Ford Ranger 35s on Method MR305 NV wheels on Ranger Raptor :) IMG_7617
dennisyin84
dennis
Nebraska
Did those require hub rings as well?
Hofstetm
Hofstetm
Mitch
Sorry for the late reply - yes they do. But they came with them when ordered. You can see the purple ring in the image below.
Ford Ranger 35s on Method MR305 NV wheels on Ranger Raptor :) IMG_5432
