Auto Start/Stop and Auto Hold Settings?
superakcraig
Allen
Louisville, Ky
2024 Ford Ranger Lariat
Besides pressing the disable button or doing something more drastic to disable it permanently, does anyone know of way to prevent the truck from Auto Stopping when you are trying to park it (either in a spot outside OR in a garage)? Is there a setting I am missing?
One would think that if the sensors are beeping warning you of something close to the truck in your garage and in my case a shelf on my wall, that the auto stop would not auto stop.
I don't mind that feature honestly except when I am trying to park it. Coupled with the Auto Hold, which I discovered only recently, it doesn't work well at all. I had to disable the Auto Hold when I parked it in my garage. As you probably guessed it, my garage is SMALL (attached to my house).
twaderobyn
Tony
Joplin, Mo
2024 Ranger Lariat
Admin
I’m not sure about that, but I have an additional issue with the auto stop in my new 2024 STX. Previously in my Lariat, in auto stop and hold mode at a light, if I adjusted anything in the vehicle, it would release and start the ignition whether it was a blinker, turning the steering wheel, or depressing the brake or accelerator, whatever. In my new 2024, the auto stop, especially in conjunction with parking hold assist at a stoplight, I have to depress the brake and/or the accelerator in order to wake the vehicle up and release the hold, which causes a delay of second or so, which seems like a lot in a fast situation and has already proven awkward as people behind me think I’m asleep at the wheel.
superakcraig
superakcraig
Allen
Louisville, Ky
I’m not sure about that, but I have an additional issue with the auto stop in my new 2024 STX. Previously in my lariat in auto stop mode at a light if I adjusted anything in the vehicle, it would release and start the ignition whether it was a blinker, turning the steering wheel, or depressing the brake or accelerator. In my new 2024 the auto stop in conjunction with parking hold assist at a stoplight. I have to depress the brake and or the accelerator in order to wake the vehicle up which causes a delay of second or so, which seems like a lot in a fast situation and has already proven awkward
I do know what you are experiencing is the auto hold and that’s what it’s supposed to do until you hit the gas pedal, and yes, there is a slight delay as opposed to you slightly letting off the brake yourself and thus causing the vehicle to restart.
KevR
Kev
AZ
24 Ranger Raptor in AGM
I agree, I like Auto Hold but hate it while parking AND also I went through an automatic car wash where you have to be in neutral and the Auto hold was on and my tires were skidding on the track and it caused the machines to shut down 3 times. I'll have to turn it off next time beforehand.
Coastal
Los angeles
2024 Ranger Lariat
I discovered a workaround for the auto/hold feature which can be a nuisance when trying to park in a tight space with either a wall in front or behind.
When creeping up to a wall I release the seat belt. The auto/hold feature is temporarily disabled if you remain under idle or just above and you can control the vehicle with the brake only. I find it easier to park without having to hit the gas to release the hold (tends to be a little jerky)and thereby avoid driving into a wall. Added bonus is the seat belt warning doesn't come on when idling in either!
superakcraig
superakcraig
Allen
Louisville, Ky
That’s good to know, nice find, thank you for sharing!
