Bed Cargo net suggestions
ellisina4
Yuri
AZ
Our Ranger RR came from the factory with the Bedliner Tough Bed Spray-In. I added the backflip MX4 cover afterwards.
Is there a good OEM or aftermarket bed cargo net you guys have experience with that can be attached towards the rear of the bed? Just want to make sure that a gym back or work bag can be left in the bed and not having to worry if either of the bags is sliding around and getting scratched up on turns or hard stop.
Thanks
RangerRider
Patrick
Watertown, SD
2024 Ranger Lariat 4 x 4 (Hot Pepper Red)
Muslogy is in the process of making one for the 2024 Rangers.
I’m currently testing a prototype.It had 4 mount points at the rear of the bed and can hold items from sliding out if the bed as well as holding thing internally within the net.
I’ll forward your interest to the person I’m working with. Attached is where the mount points are, so you can verified the Ranger Raptor bed has the same mount points.
R
mackieranger
MACKIE
Southeast
2024 Ford Ranger XLT FX4 cactus gray
Sr. IT Manager
Brito
2024 Ford Ranger Raptor, 2011 Corvette Grand Sport, 2006 HDStreetBob
Breakthrough
Ontario, Canada
2025 Ford Ranger XLT
Are the holes in the bed pre-threaded? Did you have any issues with the bolts with the bedliner? (hard to tell if mine have threads or not with the overspray)
RangerRider
Patrick
Watertown, SD
The 6mm and 8mm holes in the bed are threaded. I did have to clear out some of the overspray in the 6mm holes.
The supplied eye-bolts then just threaded in normally with no problems.
I have not received any status update from Musolgy as to when these will be available.
I go to the junkyard and get one from a toyota camry and use it in my trucks under the covers. They are about 4 bucks and usually are still in the original packaging. Then you can use those prethreaded holes mentioned above
Awirez
R
Product recommendation, make the anchor points smaller style D-rings, so they are not as exposed when not in use. Also, enough resistance to keep them from bouncing around when not in use. Somewhat of an example below.
RangerRider
Patrick
Watertown, SD
Received response from Muslogy . They are expecting to be available in about a month.
They will announce when available on this forum
