Bed Tie Down Hook Bolts!
Mgrmax
Detroit
So, I was trying to remove the tie down hook bolts and bolt head snapped off. Looks like they used blue lock tight. Feels like red lock tight.
Ford Ranger Bed Tie Down Hook Bolts! IMG_0949
Ford Ranger Bed Tie Down Hook Bolts! IMG_0948
stuartmunto
Stuart
Perth, Western Australia
2023 Ford Ranger Raptor
Yeah, you need to take these bolts out really really slow - even go back and forth to losen up the loctite. I suspect you'll need to have this drilled out and retapped. Looks like it scuffed the bed liner up some too
Mgrmax
Detroit
This was SUPER surprising to me. I removed the hooks on my 23 Ranger with no issues. With regards to the bedliner, I sprayed it in myself and it’s an easy touchup. Thanks for the reply!
Deleted member 9086
Did you use an impact gun? Only way to get them out correctly.???
Mgrmax
Detroit
I did and they did not budge. Ended up using channel locks to try and get more purchase. When I say these suckers were glued in, it is an understatement. Someone went ham at the factory?
FloppyKnockers
Fort Worth, TX
2024 Ranger Lariat
Ford doubled-down on mine by spraying bed liner over them, filling the heads with bed liner turning any future attempt at removal from a task to a project. I can't even tell if they're torx, Philips, square, or what... I guess they're structural now.
Shadow Black Ranger Rapto
St. Louis, MO
I had a similar experience. Had to hammer torx driver into spray in bedliner from the factory. Three bolts gave up grudgingly, but stripped the head of the fourth. Broke an easy out and resorted to using channel locks. Ugh, shouldn’t have to be that hard…
UpInTheAir
NA
Patience
They're Torx Plus, which I didn't realize was a thing until I removed mine. I replaced all four (from the ARB air compressor install on passenger side) with black oxide stainless bolts that are regular Torx from BelMetric (https://belmetric.com/torx-button-flange-black-stainless-m8x1-25-coarse-iso-7380-2/) for less than the cost of a single OEM bolt from Ford. Tensile strength PSI is lower than a regular carbon steel bolt, but I don't think it should matter for me since I am not using the tie downs all that aggressively.
Edit: Forgot to mention that I did have to chase/clean out the threads before bolting the tie downs back up. They were completely full of loctite, and there was way too much resistance to try to comfortably screw in the new bolts otherwise
telenerd
Laramie
What size of torx plus are they? I plan on getting bed molle and don’t wanna fug them up.
UpInTheAir
NA
Patience
Think my regular torx T40 was slightly small for them but mostly worked getting 3 of 4 of them out so probably a Torx Plus T40? Had to use big channel locks to get the last one the rest of the way out.
If you have a spray in bedliner and Ford sprayed over the tie downs like on mine, use a utility knife to score around the bolt heads and tie downs so you can peel the material off and out before trying to unscrew the bolts.
Chugginalong
Eric
Central Florida
2024 Ranger
I just purchased a 2024 Ranger and the bolts had red lock tight on them. You have to take them out to install the modular bed liner. I heated the bolt to 195 degrees and still couldn't get it out with channel locks. I'm going to try and cut the end of the bolt and then use an bolt extractor. Hope you get yours drilled out. There was no reason to use red lock tight on these. Blue would have been fine.
Mgrmax
Detroit
I tried the screw extractor like Roverhound suggested and it didn’t budge. Probably going to drill it out and retap. Nothing like drilling into a new truck. This is becoming annoying…
Chugginalong
Eric
Central Florida
2024 Ranger
mgrmax, Sorry to hear you're gonna have to retap it as there isn't much meat in the metal there. I finally dremaled a rectangle head on it and then used a 13mm wrench on it. With some patience I finally got it out.
