dpAtlanta
Just North of Atlanta
The last time I installed wheel spacers was on a new 2003 Cobra. Ford tucked the wheels in too much for my taste.
I had zero issues. The Ranger Raptor looked like the wheels were tucked in too much as well.
I installed Titan wheel spacers, and I think it looks better now.
I also placed a flat edge against the front and rear tires and made a mark on the concrete to measure the track width.
The front now measures 81", and the rear measures 81 3/8".
I guess it is now into identification light territory width if I wanted to validate putting the three lights in the grill.
They look cool, but no current plans.
BEFORE:
Ford Ranger Before/After with 1" wheel spacers 91759-ecd0a32505770390932a33305be7e35c
Ford Ranger Before/After with 1" wheel spacers 91758-2ee08b8450c287a0cc10f01b80485e07
AFTER:
Ford Ranger Before/After with 1" wheel spacers 91760-67bc1c74ada797899ab17be4397c77fa
Ford Ranger Before/After with 1" wheel spacers 91762-15e05c24f0d81e49ae2fbb05a9e0bd91
I used 1" spacers on my ranger and it did indeed look alot better, also
skytrucker
Andy
Illinois
2024 Ranger Lariat
Looks good!
raises a question for me (I have no spacer experience,) is there any difference between spacers vs an equivalent wheel backspace/offset?
1” =about 25mm, would they be the same as a wheel with a 25mm offset (or 25mm different than the current wheel, atleast)
danmoochie
dan
florida
retired Sales manager
I love the look but still fear adding another failure point or causing possible suspension issues. My XLT FX4 would look way better with a set.
BeachRaptor
Virginia
2025 CGM Ranger Raptor, 2024 Terra Toyota TRD Pro 4runner
Looks good!
It’s inexpensive vs buying new wheels.
NASSTY
ME
For me it wasn't an expense thing. I like the non-beadlock Raptor wheels more than any aftermarket wheels that I've seen yet so I added 1" Bora spacers. To get a slight bit more poke I went with 33x12.5x17 tires.
Ford Ranger Before/After with 1" wheel spacers e721aa57-bcf1-4bbe-8800-ea9052afa46
BeachRaptor
Virginia
Not saying it’s always the reason. I used em on my wrangler for a couple of years. For me it was a cost thing. I saved for a while to buy new wheels so i could take the adapters off eventually. I never liked the stock wheels that came on it.
BeachRaptor
Virginia
I guess it is now into indicator light territory width if I wanted to validate putting the three lights in the grill.
BEFORE:
AFTER:
BEFORE:
AFTER:
They definitely improve the stance. Looks good OP!
Switzguy
Minnesota
Looks good! Might consider doing this myself.
K_teven
Steven
Retired Diesel Engineer
Very nice! I already added the ambers in my grill but I went with a four light set. Mine were under eBay Item # 305283610961. Wired them into the Aux Switch #1 easy as can be. Can you provide additional details on your Spacers? Thanks.
dpAtlanta
dpAtlanta
goober71
Ro
Houston TX
2024 Ranger XLT 4wd
Looks great! Will these fit a 2024 XLT FX4? Also, it mentions you may need to grind the lug studs if they are longer than the thickness of the spacer. Did you have to do that?
G
dpAtlanta
dpAtlanta
G
It says it will fit all 2019+ Rangers.
I did not have to grind anything.
If I did have to grind or modify them, I would not have purchased them.
goober71
Ro
Houston TX
2024 Ranger XLT 4wd
That's great! I'm definitely considering trying them out!
G
