Brake system warning after software update.
swank
New Jersey
2024 Ranger
Audio Engineer
I am wondering if anyone else has had a bug resulting in a brake system warning light on the dash. My truck updated the software last night and this morning when starting it up I got the “brake system warning” notification and the brake light on the dash staying lit. Everything feels normal and my truck only has 16,000 miles on it. Is this a bug or do I have to look at my pads or lines? I checked to make sure the emergency brakes were disabled and it was.
i didn't but i notice the alarm that tells you to watch out because it thinks you are going to run into something comes on alot sooner than it used to
swank
New Jersey
2024 Ranger
Audio Engineer
After looking in my app. I found that it is my ABS that is malfunctioning. Not sure how that would've happen but I am just hoping it is under warranty or better yet just a bug in the system.
BriSco
'24 Ranger XLT, 2.7L V6
Mine did that also after the BCM update. Cycled the ignition a couple of times, pulled it out of the garage and it went away. I’ve driven it a couple of days and it didn’t come back.
AugPal
Augie
Chicago
Retired IBEW
Doesn't Ford do any testing of updates? This is ridiculous.
I'm going to go check my truck
ADDENDUM I just checked my truck, and it didn't show any update or any warning.
My Ford app says my last update was on April 24, 2026 Software Update 11 - Center Touchscreen SYNC-24-2.4.10
Can anyone else check there Ford app for your update number?
swank
New Jersey
2024 Ranger
Audio Engineer
Mine did that also after the BCM update. CycleD the ignition a couple of times, pulled it out of the garage and it went away. I’ve driven it a couple of days and it didn’t come back.
Hopefully it is the same for me. I had to get to work this morning so I wasnt able to mess around with it. I will update after work
my most recent is bcm-25.7 on 25 may 2026
rocsteady
New Jersey
Federal LEO
I got the warning Tuesday morning. The red brake light that illuminates when the parking brake is engaged stayed lit until I turned the truck off and back on again after driving about half a block. Was fine the rest of the drive but it's been sitting since.
swank
New Jersey
2024 Ranger
Audio Engineer
The update I did overnight was BCM-25.7.0 which was a rear wheel speed sensor update and a Body Control Module. Which could make sense for the ABS code if the wheel sensor is bugged.
AugPal
Augie
Chicago
Retired IBEW
On my Ford App my April 24,2026 update was just a release notes
I just checked all my updates and I got BCM-25.7.0 on 5/15/2026. I wonder why I got it so early?
Ford Ranger Brake system warning after software update. fordupdat
r1chi3
2024 Ford Ranger XLT FX4
Had the same issue. said ABS system malfunction in the app. After one drive it was cleared out and gone
MK8.5 Golf R
Victor
S.C.
1998 Ford Ranger
I had mine done at the dealership several months ago, it's all good.
Relax, Nancy. Just cycle the power off/on to let the update reboot. It isn't a big deal.
