az ranger
- Thread starter
- #1
Good evening, I have searched both bronco and ranger forums on this as I'm having cabin vibrations at highway speeds around 70 mph+. Typically its a gradual shake and comes and goes. Not really noticeable <60 mph. If this has already been answered/addressed, please share because I cannot find a good answer.
At approximately 10k miles on my 2025 Ranger lariat sport, I put on a 2.5 superlift level, fuel rebel 6x139.7 +1 and BFG ko3 285/70/17 tires, and also got alignment completed. I will say, they were originally listed as tacoma, but looking at the hub bore, assuming the wheels are tacoma hub bore of 95.1 as opposed to the 93.1.
I was experiencing vibration in the tires right from the get go. I had costco try and balance x3 within 6k miles. I then took them to discount tire where they road force balanced. They were better but still was getting cabin rattle at highway speeds. Discount tire warrantied the bfg's and replaced with falken wildpeak at4's, 275/70/17. I went smaller as falken's to match bfg weight (think bfg's were 65 lbs, falkens smaller are still 66 lbs). And falkens are a better overall tire, but I'm still getting highway rattle.
I took to an independent mechanic chain to see if there is anything they can find, and their recommendation was for hub centric rings, but I had thought the wheels were 106.1 as listed on fuels website, not the 95.1 bore to the tacoma. Found that out after I went back to discount to install the hub rings, and the tech told me they were now "within stock balance standards" something to ~ 35?
I have tried to read even the bronco forums on this issue as they are on the same Ranger platform, and one of the threads were talking about the driveshaft being out of alignment after leveling kit, or driveshaft balance?
I really like this truck and the 2.7, and I understand with a/t tires it's not going to run like a cadillac, but I'm running out of ideas on how to fix this issue. Also, like a dummy, I sold my oem wheels so I can't just throw them on to compare the ride. I've considered getting bronco sasquatch take offs because I don't think stock ranger 17" wheels with the +55 offset will not rub with the larger tires. The sasquatch wheels are +25 offset from what I've researched. Or again, should I get the stock ranger and through a hubcentric 1" spacer?
Any advice or suggestions are appreciated!
