Cabin Vibrations at highway speeds (70 mph+)
az ranger
peter
arizona
2025 ford ranger lariat
Good evening, I have searched both bronco and ranger forums on this as I'm having cabin vibrations at highway speeds around 70 mph+. Typically its a gradual shake and comes and goes. Not really noticeable <60 mph. If this has already been answered/addressed, please share because I cannot find a good answer.
At approximately 10k miles on my 2025 Ranger lariat sport, I put on a 2.5 superlift level, fuel rebel 6x139.7 +1 and BFG ko3 285/70/17 tires, and also got alignment completed. I will say, they were originally listed as tacoma, but looking at the hub bore, assuming the wheels are tacoma hub bore of 95.1 as opposed to the 93.1.
I was experiencing vibration in the tires right from the get go. I had costco try and balance x3 within 6k miles. I then took them to discount tire where they road force balanced. They were better but still was getting cabin rattle at highway speeds. Discount tire warrantied the bfg's and replaced with falken wildpeak at4's, 275/70/17. I went smaller as falken's to match bfg weight (think bfg's were 65 lbs, falkens smaller are still 66 lbs). And falkens are a better overall tire, but I'm still getting highway rattle.
I took to an independent mechanic chain to see if there is anything they can find, and their recommendation was for hub centric rings, but I had thought the wheels were 106.1 as listed on fuels website, not the 95.1 bore to the tacoma. Found that out after I went back to discount to install the hub rings, and the tech told me they were now "within stock balance standards" something to ~ 35?
I have tried to read even the bronco forums on this issue as they are on the same Ranger platform, and one of the threads were talking about the driveshaft being out of alignment after leveling kit, or driveshaft balance?
I really like this truck and the 2.7, and I understand with a/t tires it's not going to run like a cadillac, but I'm running out of ideas on how to fix this issue. Also, like a dummy, I sold my oem wheels so I can't just throw them on to compare the ride. I've considered getting bronco sasquatch take offs because I don't think stock ranger 17" wheels with the +55 offset will not rub with the larger tires. The sasquatch wheels are +25 offset from what I've researched. Or again, should I get the stock ranger and through a hubcentric 1" spacer?
Any advice or suggestions are appreciated!
AugPal
Augie
Chicago
Retired IBEW
Were you having the Vibration issue with your OEM wheels?
az ranger
peter
arizona
…and was the suspension modified at the same time the new wheels and tires were installed?
So I had done everything within a week of each other. I just did the lifetime alignment through firestone so I immediately got the alignment on the way home from the spacer iinstall and then again after the wheel/tire combo was installed.
The reason why I don't notice that often is I work from home, and drive surface streets and vibrations not noticeable. And here in AZ, the freeway is under construction so speed limit is 55 (which go a bit faster, but not 75+) and the roads under construction, so I brushed it off as the road is unever/under construction so ride quality varies. But when I'm on a smooth stretch of freeway not under construction, that's where I notice the most.
5G Rangers had a rough time with drive shaft balance issues, usually due to pinion angle being off. As little as 1 degree makes a difference. Many went with a one-piece drive shaft that cleared the problem.
And I'll leave this here, for reference only,
Ford Ranger Cabin Vibrations at highway speeds (70 mph+) 1789653896946-3z
az ranger
peter
arizona
Appreciate the reply Jason, and my post was a little convoluted, but that is why I now have falken's on the truck. They do definitely ride better than the k03s, but the freeway vibration is still there. I have looked at the driveline as being the possible culprit in this case too. But want to rule out the wheel/tire/level combo first. Something keeps bringing me back to the hub difference on the fuel wheels.
bigb
Tucson
2025 Ranger 2.7
There used to be shops that could balance the wheel and tire assembly on the vehicle, not sure if you can find that anywhere these days though. That could rule the hub difference out.
Other than that maybe look for a set of takeoffs for testing then resell when finished.
MJ12
MJ
Batman
Check that you're in 2WD?
Now that I think about it, I sometimes have a little vibration at high speeds. Here in Louisiana, it's rare to find a nice smooth road to rule out road issues. I also have a 2.5 level lift, but with stock wheels and tires. Maybe the lift throws out the pinion angle? I thought maybe I screwed up one of the axle CV joints, which I need to check out.
As I mentioned, 5G had driveshaft vibrations, but those had standard U-joints, whereas 6G uses a CV at the rear axle. Would that matter? I don't know.
az ranger
peter
arizona
Confirmed 2wd only. Don’t even think I’ve had to throw it in 4h or low since I’ve had it. It’s been a mall crawler.
MJ12
MJ
Batman
Hmmm just checking... I drove around for about 15 minutes one day not realizing somehow the mode got changed to to 4H
Same here. Left home one morning and steering felt funny. About 5 miles down the road I realized it was in 4WD. My assumption is that I accidentally hit the button instead of ASS.
Back to the original issue. I now think I have a different vibe issue than OP, as I feel it at lower speeds, too, starting around 30 MPH.
Morningpride
Philadelphia
2024 Ranger LT STX
You need to verify if the vibration is coming from the wheels/tires, or the cv joint angle. I would think that if the tires were changed, and you still have a vibration, it might be those front driveshafts. I experienced this exact scenario on an older IFS Toyota. Lifted the truck 2 inches and it had a vibration when the hubs were locked. Unfortunately for us, the front driveshafts spin all the time. When you add those “puck” spacers, it throws the cv angle out of whack. 2.5 inches is a LOT for a puck level.
Arsenall11
Maple Valley Wa
Mechanical contractor
My sons is 1.5” puck stock wheels, 1.5”spacers hub centric KO3, no vibration. But, it did eat a cv joint that still turned but caused a vibration. Our dealer changed it under warranty no issues now.
Ford Ranger Cabin Vibrations at highway speeds (70 mph+) IMG_0440
