ADVNTURR
Cleveland, OH
TLDR version: I made a custom bed rack for my truck
Ford Ranger Custom Bed Rack Build DIY PXL_20250725_192412007
I picked up my ’24 XLT last year with the goal of using it to tow my track car, shuttle canoes and dogs around, take care of home projects, and hopefully do some overlanding eventually (including camping at race tracks). The towing part has been going really well and so has the dog toting, but for the canoes and overlanding I needed a rack.
Ford Ranger Custom Bed Rack Build DIY PXL_20250503_210337327
I did a lot of looking at what was available and learned about all the pitfalls of Ford’s spectacular decision on the plastic rail caps and the J-Brace situation. Adding to the search complication, I have a Bestop Supertop 2 soft top/tonneau cover on my truck which basically eliminated everything off the shelf (Xtrusion Overland, KB Voodoo, and a few others have offerings for the Softopper brand but Xtrusion at least specifically says it won’t work with the Bestop version).
Since simply buying something wasn’t panning out, I decided to make my own and pull concepts from the brands I liked and try to keep it as versatile as possible with some compatibility for existing accessories. After taking some measurements, I started mocking everything up in CAD and then started making some 3D prints to make sure things matched up to my dimensions and ideas.
Ford Ranger Custom Bed Rack Build DIY ranger_rack
Ford Ranger Custom Bed Rack Build DIY PXL_20250619_011709792
With the plastic rail cap issues and everyone trying to make pucks and such to support any useable load, I decided to go a different route and go under the caps and simply notch the caps as needed. With an order to Send-Cut-Send and some help from a friend for some SS welding I made up some mounts out of 3/16” 316SS
Ford Ranger Custom Bed Rack Build DIY PXL_20250703_125709645
Ford Ranger Custom Bed Rack Build DIY PXL_20250713_163141958
The brackets bolt directly to the top of the bed rail with the rear mounts centered over the “stake pocket” and the front mounts offset forward a bit to get a bit more span and to better center the rack on the bed. To help protect the bed rails and to help keep water/dust out I did put down a layer of PPF before bolting everything down and simply slit the film where I needed bolts or the rail cap clips to pass through
Ford Ranger Custom Bed Rack Build DIY PXL_20250713_173731292
Ford Ranger Custom Bed Rack Build DIY PXL_20250713_173718603
With the mounts in place I used a utility knife to trim and notch the rail caps so that they would snap back down. This obviously won’t be ideal if I choose to sell the truck in the future or upgrade to a fully integrated overlanding topper…but that’s a future problem. I did loose a few of the clips that hold the caps down, but with the Bestop rails clamping down on the caps, they’re not going anywhere.
Ford Ranger Custom Bed Rack Build DIY PXL_20250723_011929223
Ford Ranger Custom Bed Rack Build DIY PXL_20250723_011939391
As may already be obvious, I chose to run an extruded aluminum profile for the bar work. Again, trying to be versatile and have compatibility with existing rack designs, I am using 80/20 brand in a mix of 1530 and 1530LT profiles (1.5” x 3”) and I chose to use the clear anodize as opposed to trying to go black since I hoped it’d compliment the chrome package on my truck. With the mounts taken care of I needed to take care of the upper corners so I had some billet aluminum brackets machined as well as some gussets cut. I also borrowed the Xtrusion stealth end bracket idea for the longitudinal bars and had some of those cut as well.
Ford Ranger Custom Bed Rack Build DIY PXL_20250707_225517083
Once I had all the parts and everything was test fitted, I painted anything that wasn’t powder coated or anodized and splurged on some dress-up hardware from ZSPEC Design that I use for a lot of engine bay and other parts and bolted/Loctited/torqued everything down. A side note here, I built this entire rack using metric hardware, since the rest of the truck is metric, and I’m hoping to keep everything to just 2 hex sizes for additional accessories and periodic torque checks on all the cap screws.
Ford Ranger Custom Bed Rack Build DIY PXL_20250725_020942368
Ford Ranger Custom Bed Rack Build DIY PXL_20250725_021157881
Ford Ranger Custom Bed Rack Build DIY PXL_20250725_021011958
Ford Ranger Custom Bed Rack Build DIY PXL_20250725_021003347
Overall, I’m happy with the end result and it should give me a good platform to work from over the next several years. Did I save money by doing this? No, I ended up spending ~20% more than a similar Xtrusion rack but I have some spare parts for future accessories and I didn’t exactly try to save money with things like the dress-up hardware.
The rack does sit a bit high, but I am hoping this will allow canoes to clear the cab and it also makes it possible (but not easy) to fold the soft top forward or swap to the tonneau. With the extra height and width, the rack is going to catch a lot of wind which will make some noise and will have some effect on fuel economy, especially when I have a tent or canoe or other stuff on top. But, this isn’t my daily vehicle and it’s a rolling brick made by Ford, not a Rolls Royce, so it’s not like it was slipping silently down the highway to begin with.
For those inevitably concerned about my mounting method and that I’m going to destroy my bed rails and pry them open like a tin can, I promise that as long as I keep the hardware tight between the extrusion and the mount I am not prying out on the rails. I can unbolt the rack and jump on it and the mounts don’t move or flex off the rails (if I heavily load the center of the cross bars I actually start to pry inward slightly). I also intentionally made the mount bracket bases large to distribute the load better than the pucks most people are using and I have large plates under the rails to protect from wind loads pulling up on the rack when canoe(s) or a RTT and awning are on top.
Next step, finally install my J-Braces and mounting the RTT I bought off Marketplace and giving things a shakedown
RealTruck
Ocala, FL
Ranger
Thoughtfully planned and masterfully executed from start to finish. Very well done!
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
I chose to line the inner surfaces of my front rail cap with gorilla tape for the surface contact and with hand machining it fits tight and flush when bolted down
Fawnbuster
Indiana
Great job! Looks strong enough to make your hair defy gravity! Oh wait...
Wolfman00
matt
crofton md
2024 xlt
damn, that looks awesome!
i ended up with the new xtrusion rack, took them some time to get the brackets correct, and they haven’t dialed in the stake pocket inserts yet- so i went to SCS and designed my own. SCS is awesome!
ADVNTURR
ADVNTURR
Cleveland, OH
That's really slick. Did you use a standard square tube section or some other profile and then machine to fit? I've thought about making some aluminum rail caps to replace the plastic ones, but I just kind of went around the whole situation here for the time being.
ADVNTURR
ADVNTURR
Cleveland, OH
I've been watching your various setups and saw your post about getting one of the early Xtrusion setups. I still think they're making a cool product but I'm still not sure on their mounting on these trucks (and again with my topper setup it really wasn't good to work well anyway).
SCS is great and now that they're getting into CNC machining options it's just going to be that much more versatile. I used Xometry for my billet corners which worked well but now I want to quote them through SCS to see how they compare.
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
That looks awesome! So I sourced a 8' stick of 1.5"x1. 5" x 1/8" of the ano aluminum L angle and cut to length using a cardboard template/saw guide and fine blade hack saw. Relief machined 2 very small corner surfaces where sheet metal was doubled up/welded on factory box, used a bench grinder for that. Dry fit and ink transfered the 2- 8mm bolt locations plus 2 smaller holes for " cleat" anchor leg to sit in. All in for ~$40 and used a bit more than half the aluminum stock
ADVNTURR
ADVNTURR
Cleveland, OH
That's solid fab and CAD (cardboard aided design) work. Using the factory holes and added the tie-down points was another nice touch.
I ended up adding some L-Track to my bulkhead and my topper/tonneau is designed to fill the gap which is working for now
Ford Ranger Custom Bed Rack Build DIY 1000008873
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
Yes, so this area zoomed in your photo shown directly to the left of the horizontal track length was where both squarish corners (bump out areas) required relief machining for the cap to lay flush and flat and in both corners that very small area was not exactly the same dimension in area, thickness probably was same though. This was due to sheet metal being doubled up/welded in those 2 small corner areas...
Ford Ranger Custom Bed Rack Build DIY Screenshot_20250731-081849
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
And the specialty blue cap/cup style bolt washers is interesting, I only have a few of those type of washers and they are an interesting design
YukonRanger
Yukon
If you want something done right
ya gotta do it yourself
Well done bud
clarke
Tennessee
2025 Ford Ranger Raptor
Did you use rivnuts for attaching the l-track or did you have to take the bed off?
I'm looking to do something similar.
