Dash Cam Fuse Taps
HyperM3
Lawrenceville, NJ
It gets worse with the trimming of the micro3 fuse tap lol. Yeah I know. You can probably use one of the micro2 slots as accessory but I didn't like the idea of tapping into what any of them were tied to. The fuse charts are not very informative on what the actual fuses are linked to, the labeling in the manual is terrible. If someone can find a better and easier solution I'll be grateful but this should work fine just with the added effort.
Yeah, in every other car Ive always tapped the Homelink fuse but I cant find anything with that label on it.
Rapture2423
Midwest
I'm going to try this micro 3 fuse tap. Single review said it did not need trimming and the photos don't appear to show the raised outer edges. I'll report back on the fitment and quality.
https://a.co/d/g3WcLuO
I picked up some Bussmann ATR and ATL 5 amp fuses. Never know what you're getting in kits or Amazon. Will cover the crimp with heat shrink tubing also.
HyperM3
Lawrenceville, NJ
I don't know what I'm doing wrong but I can't get any power going to my dashcam, with truck started or turned off. I have power on 28 and accessory on 22. I even swapped the wires around and still didn't work.
Ford Ranger Dash Cam Fuse Taps PXL_20240515_135357664
Rapture2423
Midwest
You missing a fuse on 21+22 tap?
HyperM3
Lawrenceville, NJ
I mean, I dont have a spare 3 prong fuse to throw in there. I have the OEM fuse in there as the only one. Would that really keep it from getting any power?
Rapture2423
Midwest
Not sure to be honest but since 21+22 is already only 5 amp I don't think it would hurt anything. Just going off what I noticed.
Does your dashcam come with a 12v cigarette lighter power cord? Can you confirm the unit is good to go with a known working power source first?
Your new 5 amp on 28 looks fine. The 30 amp on 28 and the 5 amp on 21+22 good and not blown?
The other thing would be to check your crimp connections.
Wayfaring Ranger
STL
Whats wrong with the dashcam that ford sells?
it's incredibly overpriced for what you get and likely has less features than a similarly-priced model. which is basically the same story for everything on the ford accessories website.
you're paying a premium for an inferior product because ford put their branding on it.
Rapture2423
Midwest
There's another part of this thread that breaks down which prong is the "hot side"
If you don't have both fuses in the tap and if the fuse tap is in the incorrect orientation it would not work.
HyperM3
Lawrenceville, NJ
Figured it out. I had to move the single fuse on 22 to the other open spot. Now its all good and working. Time to route the cable. Thanks again for your quick responses!
Rapture2423
Midwest
Nice I was able to find a micro III 5 amp fuse at AutoZone if you're ever looking for one
Cyrusblack
Banned
Banned
Pasco County
I just installed my Viofo A229 Pro front and back with their optional hardwire kit and it all works perfectly.
Ford Ranger Dash Cam Fuse Taps Front Camera 01
Ford Ranger Dash Cam Fuse Taps Front Camera 02
Ford Ranger Dash Cam Fuse Taps Rear Camera
Ford Ranger Dash Cam Fuse Taps Viofo Hard power wir
Cyrusblack
Banned
Banned
Pasco County
Yes - my wiring installer put the back camera on the tinted window crooked. It is not level and my OCD cannot stop looking at it ?
jrRaptor
Maize, KS
My OCD wouldn't like that it's not on the center window lol. Hey crooked cam is better than no cam. ?
Cyrusblack
Banned
Banned
Pasco County
Yeah - I guess so but dollars to donuts that within 2 weeks from now I will pull it off, re-tint and put it on level myself.
Rapture2423
Midwest
Still waiting on my darn micro 3 fuse tap. I have everything ran and buttoned up. Just need to complete the power harness and plug it in.
Thanks again @jrRaptor for the inspiration to combine the two Blendmounts. Very pleased with the front and rear mount solutions.
When I popped off my drivers side A pillar for some reason the tweeter snapped out of its mount that's a part of the A pillar. Not sure why it was so difficult to get that seated again but that was my most frustrating part of the install.
Did my best to ran all wiring behind airbags for safety purposes. Should have the fuse tap tomorrow and be able to finish this up.
Blackvue 970x Plus 2 Channel
Escort Redline 360c
Ford Ranger Dash Cam Fuse Taps 20240519_174456
