wlarsen76
Wells
Yes, I did write something about that. I had to shave it down. I did it with scissors, if you have a utility knife and a steady hand it will be easy enough.
After some careful reading, I don't think I explained myself well enough.
I do understand now that the piece that you were talking about shaving was the part of the add-a-fuse that goes into the fuse box. That's actually not the piece I was talking about not being able to get fit correctly.
I was actually talking about trying to connect the Yellow ACC wire from the power adaptor (with a 0.25" male end) to the micro3 add-a-fuse (with likely a .187" female end).
I've been going back and forth with Wolfbox and then just want me to tape it together, but that seems like a really sketchy idea.
I'm just wondering if you ended up stripping and splicing them together or perhaps cutting off the connector on the add-a-fuse and adding on a .25 female end?
PNW_Raptor
PNW_Raptor
Jon
Washington
I didn't strip any wires... I was able to just use the connectors that came with the add a fuses. Go to home depot and buy some connectors and some shrink tubing and that will work. Would not recommend just taping them together.
ummagawd
Tommy
Huntington Beach
26 Avalanche, FJ Cruiser
Interested in a similar mod, but was concerned that the camera behind the digital rear view mirror is obstructed by the big plastic covers hiding the factory electronics. Can anyone confirm that these "cam behind the mirror" styles have an unobstructed view of the front?
PNW_Raptor
PNW_Raptor
Jon
Washington
I've been using this for almost 2 years now. You're right, the large plastic cover does block some of the view, but the camera is a fisheye lens that clearly shows everything you would need to see in front of you. You can move the camera around a bit to get a better view.
ummagawd
Tommy
Huntington Beach
gotcha... if its not too much hassle, can you post a screenshot?
