FreezingFlatlander
Montana
2021 Ford F150 4x4 3.5 Ecoboost
Thanks for the post as I couldn't figure out how I was going to get my 'End Cap' type oil filter wrench through the maze of brake lines that are in the way. Using the 'Strap' type oil filter wrench like you did solves the problem. I have been taking the Ranger to the dealer for oil changes but it's time consuming and would rather do it myself.
XLTRangerRick
CT
24 Ford Ranger XLT FX4 Velocity Blue
I have the end cap type and if you reach down from above on the right side you can fit it on. I had to buy one because my old truck had easy access and I used the strap type. If it wasn't 12 degrees out and the middle of the week I'd get a pic for everyone with the cap wrench on.
IndyBrett
Brett
Indiana
2024 Ford Ranger Lariat
EE
Jamzm
Jim
PA
2024 Ford Ranger
Could a plier type filter wrench fit ln there? At $130 for a full synthetic change, I'll start doing them myself.
jeffers
Jeffrey
Nevada
2024 Ranger FX4, Mk7 GTI
This is the best tool
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details 51DsoCICqyL
XLTRangerRick
CT
I have never used that type of wrench but there is room to use one. As @jeffers posted above it seems to work for him.
Jamzm
Jim
PA
2024 Ford Ranger
Thanks... That's the exact same tool I bought from Amazon last year.
emcmtony
tony
swedesboro, nj
I also reached from the top. No special route, extensions or tools. Just a ratchet and adjustable filter wrench from harbor freight. I have short arms so if I can reach it……
I added 6 quarts, perfect level.
so glad I tried this and didn’t listen to the wheel removal/wheel well advice.
Davko
Denver CO
2024 Ranger Supercrew FX4 XLT
I could also reach the filter from the top, but wanted to see how tight it was thru the wheel well. I lifted the truck and removed the liner which made the filter accessible. But all future changes will be from the top.
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details IMG_1833
Ford Ranger DIY: 2024 Ranger 2.3 ecoboost oil change with pictures and details IMG_1831
