T-Wrecks
Mark
Roberts, WI
25 XLT FX4
Rant on: Trucks are for hauling stuff, not people! I hate Ford for dropping the 6' bed in my 19 SC. Trucks were ruined by wannabes that should have bought an SUV. Rant off.
But I really wanted the new 6G Ranger despite the tiny 5' bed which is not good for hauling kayaks and bikes but I'll (have to) get used to it. The good news is the total cargo capacity of the CC is the same as the old SC, its just more goes inside the truck. So to maximize space and make loading/unloading easier a rear seat delete was the first thing on my list.
Within 2 hours of bringing my new Ranger home I had the rear seat out. It's just 4 bolts and it comes right out after monkeying with some elastic seat belt retainers. I haven't seen a 6G specific DIY seat delete but it's not hard to figure out (I did this on my old SC too). Using a 4' straight edge ruler I was able to find the highest point under the seat area, it's 3 raised squares along the back wall that's visible in the picture with just the short plywood piece minus the jack mount, which was cut out to get it as low as possible. I used 3/4" CDX plywood and instead of making doors to access the under seat storage I added a hinge so the whole thing lifts up, which also provides easy assess to the floor. The plywood is pretty stout so it doesn't require legs for the cantilevered part over the floor. You can see the attached underside spacers needed to support the plywood. To avoid any squeaks I glued and then nailed them with a brad nailer.
Tip, don't try and measure the locations for the seat bolt holes, use a template! I spent almost as much time trying to get those right than it took for everything else. It helped that I only had to work with the short section but was still a PITA. I used black auto/marine carpet from Menard's and 3M 77 spray adhesive with a few staples on the underside. Don't be shy with the adhesive.
I was planning on a plywood back wall too but now I'm just going to hang a moving blanket there and call it good. Not adding a back wall allows for maximum space too. I placed the jack upright and slid it under the back wall overhang so it's pretty much out of the way. It's secured with a boat battery strap but it needs stronger anchors. Not that I'll ever need to but this platform comes out as easy as the seats, just 4 bolts. There's no noticeable increase in road noise either but I might add some insulation to the back wall later. I think the total cost for materials was $75.
All the stuff I had in my SC under seat storage fits, even my 4 way folding tire wrench that's too long but fits under the plywood. My dog loves it too. I'm going to add some anchor points for securing coolers and plastic bins back there in case of an accident, or "gasp" a rollover.
Ford Ranger DIY Rear Seat Delete PXL_20251010_182244034
Ford Ranger DIY Rear Seat Delete PXL_20251011_150952265
Ford Ranger DIY Rear Seat Delete PXL_20251011_182226987
Ford Ranger DIY Rear Seat Delete 72156-14a7ea2398bcaa11f0eeac8092d95455
ATestBishop
Walnut Creek, CA
2024 Ford Ranger XL
I love me some 3M super 77 and I really think the shelf life is incredibly long. It's one of the things that is real useful to have around. I really like the design and implementation for the seat delete thanks for sharing the details.
Barely Krawlified
So Cal
2025 Ford Ranger Raptor
Dude, you did a really nice job on this. The angles, the depth, the cleanliness of the finishing work/carpeting and the functionality of it all is just spot-on.
Thank you for sharing this.
JR RANGER
JR
Auburn CA
2024 Ranger XLT FX4 4x4
That's a great idea. Wish I saw this before I built my platform.
JRRANGER
Fritz
Melbourne
Ford Next Gen Ranger Raptor
That's some very nice work, I might do the same with a 2/3 x 1/3 split but your idea is the inspiration!
Sharpix
Tony
MX
Tinkerer Fixer
Very nice work. Seems pretty well finished and quite good for your dog. Outstanding work, man. Congrats.
I will try that but with a split, trying to hide it under the seat when put down.
One question. under the seat, at the sides there is one post, each side, like long bolts with rubber Grommets. They get into a hole in the metal base when seat is put down.
I just can't imagine when are they used... Are they for preventing the seat rising up in a crash by grabbing the holes in the base?
Very nice! I sold off all my large wood working equipment years ago, I vowed that i was done making large cuts and doing complicated routing. Then I got my RR and saw how bad the cargo volume is…. oh well. At least I got back lots of my shop floor space….
Why did you choose regular CDX plywood? Cost? It really isn’t ideal for this sort of project. If you have a local source for it, and if it is even available (the Ukraine War has screwed up supplies) Baltic Birch is available in 5’ x 5’ sheets which minimizes waste for this size of a project, and it is cabinet grade. Cost varies wildly! It has much higher number of plies, it is pretty on both sides, has no filled knots and does not splinter easily, and it holds self threading fasteners better. But even so, it is ideal to use machine screws and threaded tee nuts underneath. I don’t think that glue and staples or brads by themselves is strong enough.
This is very close to me, so I can pick it up, I would not like to have to pay shipping too…
https://www.windsorplywood.com/products/baltic-birch-cabinet-plywood
Thanks for posting, it is a lot of work to post a nice how to thread.
I think that looks awesome and you did a great job, though i too wondered why the wood type was chosen but i googled it to make sure i knew what it was and now i see why you did it.
I dont know enough about what woods work good for what but the description for that type of wood seems like a good choice
T-Wrecks
T-Wrecks
Mark
Roberts, WI
25 XLT FX4
Thanks! I bought CDX plywood for the smooth side, and it tends to warp less than other grades. 3/4" helps with that too. It's also the best option they had at Menards, $45 plus 11% off. I can always use the excess for other projects. But it does splinter when drilling (and re-drilling!) holes near the edges as you can see in the pics. But the carpet covers that. Being somewhat of a perfectionist I forced myself to let this go, but I should have remade the short section when I realized how off the holes were for the bolts. Fender washers will take care of that.
bigb
Tucson
2025 Ranger 2.7
Nice work! I did a similar thing with my Jeep. I suggest you look for some cargo blocks. They come with some cars like VW wagons but you can find them on ebay. They stick to your carpet with Velcro to secure items like boxes and coolers from sliding around.
I use D rings to hold the cooler in place and cargo blocks for the smaller boxes and stuff.
Ford Ranger DIY Rear Seat Delete cargo
Ford Ranger DIY Rear Seat Delete carpeted
Ford Ranger DIY Rear Seat Delete Car Go in plac
Ford Ranger DIY Rear Seat Delete How Car Go works
Did you use hinges to raise it? I assume you did, but I didn't see a close up of your mounting boards in your pics.
Guide posts to help align the seat to the cab during assembly, most likely.
Sharpix
Tony
MX
Tinkerer Fixer
Thanks Pablo.!
So i think i could remove those posts and not make a hole into the DIY platform base.
I will try to get a Trunk Floor tray from a SUV (the Fiberglass or plasticky type, they are somewhat lighter than wood) and make it two piece with a hinge in the middle so when It should be hidden, the half piece folds towards under seat and hopefully will fit snuggly under it.
And to access the two under seat cargo spaces it would be difficult to hinge both pieces to fold up together... What could go wrong!
SLOwag
NorCal
2025 Ranger FX4 Lariat
Looks nice! Short bed truck storage is a challenge without adding a shell. I did the same with my previous Tacoma, adding some sound deadening helped with the road noise you gain when the seats are removed.
