Driver Side Window Wind Noise
Deleted member 9086
There’s the body shop way to deal with this. Adding round rubber weather strip tubing to the already existing weather strip. It fills the gap in the weatherstripping and doesn’t allow it it collapses. It will make the existing weather strip hold it‘s shape when the door is closed.
Can be purchased off Amazon inexpensively. Use one of the existing holes or make a small vertical cut in the trucks weather strip. LI’ve the backer tubing, attach weed trimmer line to the backing tube with tape, the. Insert the in the circular tube all the way around and then seal the small verticals cut with rubber cement. Works like a charm and makes a much better seal against the chassis. ???
https://www.amazon.com/uxcell-Weather-Diameter-22-96Ft-Warehouse/dp/B0CPWHGWF3/ref=sr_1_1_sspa?crid=2RLF8KF0DBT43&dib=eyJ2IjoiMSJ9.a-572OJ5YMXImVavYglzzOLiu6ppCnj_e4Tp44VD0zgAcA-_wKaS6o4ip3FJfKE-fLAIirmMLQZPGD0UntuAShXG3JLwXdqqNWBS1MBz7n7HOmeN20fQ8UwcGbBqGpImw7DwsH-VjGfeeIkLbwp-rWMdFlKfNiHjdFM8ONrBhWUZAPdMyQgdmjRhcYd2Dr0BDRR1JHr1OMSpytP06sAa3irnZb_SfjNjO8ZEAaG0iyHbBE3p4rmtcP7hPQgAUEUbRY2wok4cyXNJf6eC77t--sQoU9pjq6obsSeuVIN9J90.4tevSiX58RYkHiT127BWkCd7sdekKRlrz9tPpZr8_X0&dib_tag=se&keywords=Foam+Rubber+Weather+Stripping+Round+Rubber+Tubing+Seal+Closed+Cell+Solid+Foam+Tubing+Strip+Black+O+Type+Weather+Stripping+Door+Window+Weather+Seal+for+Cars&qid=1728317403&sprefix=foam+rubber+weather+stripping+round+rubber+tubing+seal+closed+cell+solid+foam+tubing+strip+black+o+type+weather+stripping+door+window+weather+seal+for+cars,aps,154&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
jackal
Al
Ranger XLT 2024
Here’s how I fixed my noise issue on my truck
The whistling noise was coming from the opening inside the window door frame upper corner in my case. This was on both doors. 5mins to fix per doors, but months of annoying noise.
I use 3m Calk strip. Can be bought on amazon.
If you don’t know this stuff, super useful for automotive or travel trailer and can be easily removed. Please do your research before using it if you don’t know it.
Ford Ranger Driver Side Window Wind Noise IMG_5551
With the window down, I pulled out the window seal gently and add on each side of the inside foam square. If it don't stick, wipe it to remove any greasy residue on the rubber seal.
Ford Ranger Driver Side Window Wind Noise IMG_5547
Add some in the corner where the square foam is not reaching the frame opening. You can see the triangular frame opening. The goal is to close the air from this zone not covered by the foam.
Ford Ranger Driver Side Window Wind Noise IMG_5546
Carefully set back in place without pressing the seal and once in place apply pressure to stick the 3m calk.
After that I had only normal door wind noise like my ranger2020, but no whistling.
Is that basically the same stuff as butyl rope/tape?
GraniteRR
Robert
Maybe they didnt seat it all the way up to the top of the of the b-pillar side of the door/window frame.
I found that if you pull the channel out of the window frame (on b-pillar side of front door) just enough so you can pull it up out of the door maybe 3/8" and push the extra material to the top of the door frame, then reseat the channel, my wind noise goes away 100%. I don't know if the channel in the door is too wide and doesnt hold onto the window run channel tight enough, or if the run channel itself is bad.
However, once I put the window down, the noise returns...
Were you or your dealer able to resolve this? If so, what was the fix?
Brett0712
Connecticut
Sort of…
I took my truck in to the dealer in January as my drivers window essentially stopped working. I asked them to fix that and the wind noise. They said the wind noise was normal as they drove other rangers that made the same noise. Go figure… They took the door apart, cleaned the window run channel and lubed it which restored functionality of the window. Seems like the lube has helped prevent the window pulling the run channel down with it. Every now and then I have to pull the run channel and push it back up into the corner.
I did buy a new run channel but haven’t gotten around to installing it as I’m not sure if it’s worth taking the door apart for something that won’t necessarily fix the problem.
I also purchased some of the 3m caulk strip from several posts back that I am going to try before replacing the run channel.
Dubfound
Earth
BMW
Sort of…
Keep us posted please. Mine went into the dealer 3 times for this issue and they replaced the run channel and gaskets and still couldn't fix it. Ford ended up giving me a free maintenance package for the headache.
Brett0712
Connecticut
This is so frustrating.
I can turn the noise on by simply pulling the run channel slightly out of the corner of the b-pillar on the window. Turn it off by pushing it back up into the corner. My dealer didn't want to hear it though as they said the other rangers do the same thing, therefore, it must be normal.
If it still happens with new run channels then I would assume they need to be revised to add material into the corner to prevent wind ingress. This is essentially what jackal did a few posts above. That and the material is sticky so it helps keep the run channel in place.
Dubfound
Earth
BMW
That’s what I may attempt next with adding extra material from the above post. It’s 100% coming from the upper corner in the window near the B pillar.
jackal
Al
Ranger XLT 2024
I think the seal or door frame is just badly designed based on the fact that I had this noise on both driver and passager side.
It’s been two weeks that i did my fix and I had strong face and side winds running over 100km/h without noticeable noise coming from the upper window B pillar.
Without service bulletin, the dealer will just replace by the same seal.
I hope this will work for you or at least lowered down to a level that is acceptable while waiting for an official upgraded seal.
gregsauce
canada
2024 Ranger Raptor (Cactus Grey)
I've had my 2024 Raptor in to the dealer 4 times to try and fix this issue. The last time I was there they told me they were going to grind down the self centering bolts so they could get an even tighter seal on the door. I still have a wind noise and now its harder to shut the driver side door.
Meatbag
Illinois
2025 Ranger XLT 2.3 4x4
Glad I found this thread this morning. Truck has 1200 miles on it and I noticed for the first time driving in that I too was getting this wind/whistling sound coming from what seemed like behind my head area which would indicate the B-pillar area. My educated guess is that over the handful of times that I've had to roll my driver's side window down, it has slowly worked the seal down creating the sound.
I'm going to check it out more closely later but I'm thinking something like some 3M heavy duty double sided tape would work good up in that corner where the seal is. Sort of what Jackal did above.
Interesting someone said it was a wheel bearing issue for them and another said the mirrors...little confused by that. The most common and logical thinking here would be the door seal.
UPDATE: on my drive home form work, I very intently listened with the radio off. It was a little windy today but not gusting too terribly bad. I could hear the whistling around highway speeds. Very consistently. I power folded my mirrors in during these speeds and the whistling stopped instantly. I did this multiple times on different stretches of road at varying highway speeds. It definitely has to be the mirrors in my case. The seal channels for me look fine.
Meatbag
Illinois
Update for me from this morning. Once the whistling started at highway speeds, i rolled down my window and started feeling around my fingers (insert bad joke) and felt along the crack underneath the side mirror where the mirror breaks and folds. i start tracing the crack with my finger until the whistling stopped towards the front edge of the mirror break/crack underneath.
Plan is to get some black RTV silicone and start by folding the mirror in to expose some of the openness then fold it back in and see if that resolves it.
GraniteRR
Robert
My dealer replaced the driver side mirror. New mirror housing, but reused the painted mirror cap, puddle lamp, and camera. Unfortunately, it did not fix the wind noise. The dealer scheduled me to bring it back in a few weeks for further diagnosing.
I did my own diagnosing today. I used auto body masking tape and covered different parts of the mirror until the wind noise went away. Then fine tuned where I applied tape to pinpoint the location.
My truck had full front paint protection film installed right after purchase. PPF on the front bumper, hood, fenders, and mirror caps.
I found the source of the wind noise to be the inside of the mirror cap, at the edge of the PPF. Applying a thin strip of masking tape right up against the PPF edge fixes the wind noise. I’ll either have a shop redo the PPF on this mirror, or just add a tiny strip of PPF where I have the masking tape.
I’ve never had an issue with PPF causing wind noise on any past vehicles, but am happy to have found the source of the issue.
Ford Ranger Driver Side Window Wind Noise IMG_6755
CoastieN70
Lee
Travelers Rest, SC
Retired U.S. Coast Guard
Well DAMN! This actually worked on my RR! Bought this compound from Amazon in January but had to wait for warm Wx before trying it.
Missed the first bit of warn Wx because I forgot I had this stuff. Tried it today and IT WORKS!
Of course now I'm stuck with a bunch of the calk, so... If you're in Upstate SC near Travelers Rest and have wind noise, I will be glad to help you out. No charge...
