ozraptor
If you mean a secondary lithium battery setup, there’s a bunch of options but typically you’d want to run a pair of high amp cables to the charge controller. I believe there are “all-in-one” kits these days (charge controller + inverter for your power out plugs only from it, not the truck outlets). I think some of them handle reverse charging as well though, so you’d get the extra capacity through the truck plugs too. You pretty much build this how you want it (or pay someone if you’re not quite sure).
I went the portable option (Ecoflow) because it was easiest and I could take it out of the truck for use at the camp or house. But one of these days I’ll “upgrade” to a built in lithium slimline in the cab (cleaner, more compact setup).
